Jolly Green Giant...2015 F-350 KR DRW
#9856
Howdy Roy. In the process of gathering info on the 8k axles and disc brakes for the Montana. I used your name in the initial approach to Performance Trailer Braking this week. Just to let you know...
#9857
Received 3,988 Likes
on
Are you going to do the job ??
I think the axle up-grade is a wise move...... You will be thrilled by the disc brakes.....
I am just a phone call away if ya need any help.
#9859
on
Howdy Ian....... Thanks for stopping by.
I am coming along..... This whole mess has been an ordeal for sure....... I am hoping by then end of March that I am free of pain and able to do some light work around the house..
#9860
Take it easy as long as they tell you. It is really important for recovery. Have family that have had back surgery many times for not following that. I hope you a speedy recovery!
#9861
Yes sir I am if we go ahead with it. I would love the IS but just can't see spending the extra money nor do I have the time to go get it done. If I recall correctly, it was around $3200 for it all when you had it done. The axle swap shouldn't take a couple of hours, it's the brake wiring harness getting fished up through the filon and then tying it in would be time consuming I believe..
#9862
on
Really, I think it takes longer by the time you clean everything.... and drop one end of the axle on your foot......
For sure.....It takes what it takes.
#9866
on
Optional...... And if you are smart, it is a test of your steel toed shoe...
#9867
on
I just order in band-aids by the case........
#9869
on
Stay warm Skip......!!
We hit 30°F today.......
