Jolly Green Giant...2015 F-350 KR DRW - Page 585 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
  #8761
Old 05-16-2018, 01:46 AM
Sailor_Roy's Avatar
Sailor_Roy
Sailor_Roy is offline
Sailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputation
Originally Posted by Paw's 150 Lariat View Post
Good looking job Roy...I'm impressed with the work quality!!
Thanks Don.....
I do want this rig to be much better than Keystone/Montana made it......
I am putting foam insulation along the inside of the frame and the bubble/reflective insulation where I can't get the foam. Then I am going to put foam insulation across the entire bottom....
So far the insulation process is going well. It is slow......
  #8762
Old 05-16-2018, 01:58 AM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
Roy, I can sympathize with your insulation job. I insulated my exposed fresh water tank. That was a much larger job than I expected.
How are you going to secure the foam insulation? I tried using the foam glue and it wasn't very effective. Angle aluminum worked the best and I finished with a layer of sticky backed belly material (kind of like thin tape). I'm not too impressed with the belly material. The cost wasn't justified. I made judicious use of the Great Stuff expanding foam to fill in the gaps. It's going to suck if I ever have to remove all that insulation.
  #8763
Old 05-16-2018, 02:00 AM
Sailor_Roy's Avatar
Sailor_Roy
Photos of some insulation installing.......
Whatcha think of my BIG washers.......
  #8764
Old 05-16-2018, 02:03 AM
Sailor_Roy's Avatar
Sailor_Roy
I used a BIG washer and a self-tapping screw into the frame....... (Food can lid)
  #8765
Old 05-16-2018, 02:05 AM
892504x4's Avatar
892504x4
892504x4 is offline
892504x4 has much to be proud of892504x4 has much to be proud of892504x4 has much to be proud of892504x4 has much to be proud of892504x4 has much to be proud of892504x4 has much to be proud of892504x4 has much to be proud of892504x4 has much to be proud of892504x4 has much to be proud of892504x4 has much to be proud of
Roy and family are going to be eating a lot of soup!
  #8766
Old 05-16-2018, 02:09 AM
HRTKD's Avatar
HRTKD
HRTKD is offline
Or beans. Good thing he isn't going to the G2G.
Roy, in a few cases I did about the same thing to support the foam. I cut 2" wide aluminum bar into 5" long sections and that was my "washer". Why are you putting foam insulation in the frame channel?
  #8767
Old 05-16-2018, 02:20 AM
Sailor_Roy's Avatar
Sailor_Roy
The factory design is to heat the entire underbelly......... They put the reflective bubble wrap all across the bottom of the trailer from frame bottom to frame bottom....... But, no insulation up against the steel frame so the cold can transfer into the heated space pretty easy....... By insulating the inside of the frames and plugging a bunch of holes, the under belly space will retain heat much much better....
  #8768
Old 05-17-2018, 10:37 PM
Sailor_Roy's Avatar
Sailor_Roy
No progress today...…..
Got the front and back lawns mowed before running out of steam...….. I am the new sicky in the house.
Tomorrow is supposed to rain all day...…. Already started. Saturday #5 just may be a Nap day.....
  #8769
Old 05-17-2018, 10:40 PM
Iowa Ford's Avatar
Iowa Ford
Iowa Ford is offline
Iowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputationIowa Ford has a superb reputation
Take a nap for me Roy !
I have a date with the sprayer tractor.
Hot today and nice out tonight.
Hope you get well soon !
  #8770
Iowa Ford's Avatar
Iowa Ford
Oh yeah, mowed for the 3 rd time today.....
  #8771
Old 05-17-2018, 11:24 PM
Sailor_Roy's Avatar
Sailor_Roy
Today was the 2nd time..... Good night Tim
  #8772
Old 05-19-2018, 03:36 PM
EO2SeaBee's Avatar
EO2SeaBee
EO2SeaBee is offline
Proudly Deplorable
EO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputationEO2SeaBee has a superb reputation
Hmmm. Two days with no updates?
  #8773
Old 05-19-2018, 04:57 PM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is online now
Karl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputation
Creeping crud must be taking it's toll on Roybo.
  #8774
Old 05-20-2018, 06:58 AM
EO2SeaBee's Avatar
EO2SeaBee
Proudly Deplorable
Well that's no bueno.
  #8775
Old 05-20-2018, 09:56 AM
Sailor_Roy's Avatar
Sailor_Roy
Rain Friday all day.... and most of Saturday kept me idle. Did get a little done Saturday during a break in the weather...….
A Mast mounted for my weather station sensors...…..
And the 1997 F-250 HD 7.3PSD truck of my friend, Eric.
Today after Church...….hope to get more done on the Montana...……
Quick Reply: Jolly Green Giant...2015 F-350 KR DRW
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
