Jolly Green Giant...2015 F-350 KR DRW - Page 563 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
  #8431
Old 04-12-2018, 06:45 AM
GIGGER's Avatar
GIGGER
GIGGER is offline
Posting Legend
GIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputationGIGGER has a superb reputation
Yep that's what 'they' say Eric, Grrrrrrr
  #8432
Old 04-12-2018, 07:03 AM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
Paw's 150 Lariat is offline
Paw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to beholdPaw's 150 Lariat is a splendid one to behold
Good morning everyone!
Looks like we'll have to put off our 2 night trip this weekend due to heavy rain and thunderstorms Saturday. Some are predicted to be right over the State Park that sometimes floods with heavy rain. 3 to 4 inches is forcasted.
  #8433
Old 04-12-2018, 07:21 AM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is online now
Karl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputation
Roy, those shackles can flip on their own if you lift the whole trailer at once. I've had mine flip a few times using the Level up system to get all 6 tires off the ground at once. Did you ever have all 4 tires off the ground at once? If so, that's likely when the shackles flipped. Also, to fix the issue if it ever happens again, you just use the front legs. On level ground, run them all the way to their max extension. The shackles will flip back with a bang. It will literally sound like a gun going off. The first time it happened to me (when I first got the RV and had all 6 wheels off to get my GY's mounted up), I removed a bolt from the equalizer and flipped it back by hand as I didn't realize what happened (or the easy way to fix it). When asked my buddy at XLR about it he laughed and said it happens all the time and even many experienced RV tech's don't know the quick fix. He told me about the raising the front end trick and said he's done it to a few guys to scare the chit out of them. He said he has them kneel down and watch the shackles and says, "tell me if anything changes" as he giggles and raises the nose... then BANG! and they have a heart attack and roll backward... LOL
  #8434
Old 04-12-2018, 08:39 AM
Ferguson65's Avatar
Ferguson65
Ferguson65 is online now
Ferguson65 has a spectacular reputation.Ferguson65 has a spectacular reputation.Ferguson65 has a spectacular reputation.Ferguson65 has a spectacular reputation.Ferguson65 has a spectacular reputation.Ferguson65 has a spectacular reputation.Ferguson65 has a spectacular reputation.Ferguson65 has a spectacular reputation.Ferguson65 has a spectacular reputation.Ferguson65 has a spectacular reputation.Ferguson65 has a spectacular reputation.
Rodney is 100% on the money here Roy. Both my trailers shackles will flip if all 4 wheels are off the ground at once. To save the hassle I use a strap from the front axle on both sides to the frame. Then everything lifts happy. I have had the dump trailer shackles flip once empty on severe situations like backing into an uphill driveway. Doubt it would do it loaded, or that the camper would as the springs will be flatter and essentially longer.
  #8435
Old 04-12-2018, 10:04 AM
Sailor_Roy's Avatar
Sailor_Roy
Sailor_Roy is online now
Sailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputationSailor_Roy has a superb reputation
Thanks for the lesson / feedback.......
The first time I noticed the problem, the trailer had been at a suspension shop to correct the bad tire wear problem. (which they didn't). So that is when it happened and they were too dumb to correct it.
  #8436
Old 04-12-2018, 10:10 AM
Sailor_Roy's Avatar
Sailor_Roy
Today is not the best of weather........ expected to snow late today.....
Temp is only 34F...... A wee bit chilly, but ok.
I need to finish pulling the underneath covering off......inspect / neaten up the rats nest / add insulation.........
  #8437
Old 04-12-2018, 10:28 AM
sky Cowboy's Avatar
sky Cowboy
sky Cowboy is offline
sky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputationsky Cowboy has a superb reputation
Originally Posted by Sailor_Roy View Post
2 years is all.........
Damn...that is crazy in 2 years.
I was thinking that your trailer was fairly new at just a few years old.
But with all the problems, was second guessing myself, that no maybe you bought it used and well worn already. Sorry its such a mess under there for you buddy.
  #8438
Old 04-12-2018, 10:43 AM
Sailor_Roy's Avatar
Sailor_Roy
Craftsmanship and pride in doing a good job is hard to find ..........
  #8439
djousma
djousma is offline
djousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to beholddjousma is a splendid one to behold
Well, Have you seen the photo's of Roy's inventory in his basement? Probably 5K# overweight....
Any hits on your old TH for sale Roy? If not, time for an insurance claim....
  #8440
Old 04-12-2018, 10:50 AM
Sailor_Roy's Avatar
Sailor_Roy
No news on the Raptor.......
The Montana is a little under gross weight..... Last summer I weighed it when fully loaded for our summer trip. Just under 17,000 lbs, which included about 3,000 lbs on the pin.
  #8441
Old 04-12-2018, 10:58 AM
Karl4Cat's Avatar
Karl4Cat
It's easier to spot on a tri-axle Roy. On mine, if the shackles get flipped, the center and rear tires get so close they are almost touching while the front to center axle clearance gets wider...
  #8442
Old 04-13-2018, 12:56 AM
Sailor_Roy's Avatar
Sailor_Roy
More work accomplished this morning before it started to rain around noon........ buy 1600 or so it was snowing and sticking on the grass.
Monty..... I checked the lug nuts on the 9/16" studs with the alum wheel....... No problem.
More underbelly covering removed.......
The 2nd MORryde rubber spring is damaged....... this is on the starboard side (passenger side)
After it rained awhile....... The snow started......
I wonder what tomorrow will bring..........
  #8443
Old 04-13-2018, 10:24 PM
Sailor_Roy's Avatar
Sailor_Roy
I was forced to purchase a new toy today......
I was in North40......a Ranch & farm Supply store......I was looking at the DeWalt battery powered Impact Wrench....... 1200 ft/lbs of reverse torque. Charger and two 5A batteries. $449 ($393 from Amazon). The sales guy suggested I look at the new Milwaukee 1400 ft/lbs Impact Wrench..... Charger and two 5A batteries..... $419.......PLUS $100 discount if I spend $25 on a Milwaukee accessory. There is always a small toy needed........ So the Milwaukee kit cost me $320........
  #8444
Old 04-13-2018, 10:26 PM
Sailor_Roy's Avatar
Sailor_Roy
The 2nd MORryde rubber spring that I ordered, arrived today.....
Later, the sun came out and most of the 6" of snow is melted..... I'll be back to work tomorrow on the Montana........
  #8445
Old 04-13-2018, 11:11 PM
farmert
farmert is offline
farmert has a very good reputation on FTE.farmert has a very good reputation on FTE.farmert has a very good reputation on FTE.farmert has a very good reputation on FTE.
Those impact guns are great! My son runs a Peterbuilt truck, and he likes to toy around with some of the older ones. He recently bought an old one that has set for several years. He got the one step down Milwaukee gun, and it took a rusted lug nut off of that truck that his 1inch pneumatic gun would not budge. Be warned that gun will twist the studs off of your wheels if you are not careful!
Quick Reply: Jolly Green Giant...2015 F-350 KR DRW
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
