Jolly Green Giant...2015 F-350 KR DRW
#751
Received 3,995 Likes
on
Roy - I am sure you will do this anyways, but can you post a before and after picture of the trailer connector move... Even though my new truck doesn't have 5th wheel prep, If I ever do get a fiver I will already ahve the idea on where to put that connector. I had it on my 2011 and it was always in the effing way in the factory position.
You con see the 7-pin connector just over the top of the hitch. Port side of the box, near the far back.<br/>
Where I am putting the 7-pin connector is on the inside of the tailgate .........looking between the hitch and the stripper pole.......far upper right corner of the tailgate.
#753
Interesting place... Won't that mess you up when trying to load things into the truck?
I know I load the back of mine up all the time... I guess no matter where it is, it's not going to be ideal. (Unless somehow it could be recessed in the side of the bed. )
#754
Received 3,564 Likes
on
#755
on
OK....I figured so.....trying to low ball the deal....then goto Kegs .......then to trucks, if I have to.
#757
on
It can be recessed in the side of the bed......I did it on the 2011. THe tailgate is so handy.....It will not interfere with loading stuff in the bed. A sheet of plywood goes right past it. You'll see later, the location is far to the side of the tailgate. If you were that far over to the side, sliding in a sheet of plywood, you would hit the wheel wells.
#758
on
Thanks......I had misspelled "Keg"....cag.......
#759
#760
You may need to reread the contract Roy. We already agreed on trucks! They can be aluminum trucks, but trucks nonetheless.
#761
on
Where is my twin 50 cal machine gun..........
#764
on
Yep........Dead meat......
