swapping a 5.0c6 to a 4.9 4speed
Hello everyone, hoping to get some insight on my situation
I'm trying to get out of thisnthe cheapest Incan by using everything I have.
I pulled the 5.0 out of my 83bronco with a c6 and purchased a 84f150 4.9 4speed. as parts for the bronco
I'm not sure if installing the 4.9 to the c6would be worth it because I have no kick down, also I wanna use the c6 for my 351efi. I have a flywheel for the conversion to auto.
If I install the 4.9 with the 4speed will my bronco transfercase bolt up(wanna say its a 245)or will I need the f150 transfercase?
Will my bronco front and rear drive shafts work or will I need to use the f150driveshafts? Think the rear is missing
I know my pedal assembly and ect will need to be installed? Is it doable with everything fromthe f150 or should some components be recommended replaced.
Not concerned about doing it, just mainly problems I will run into or if it isn't possible.
I have both trucks complete
Thank you guys
Thank you guys
Bronco transfer case will bolt up IF the 4 speed is a 4x4 tranny.
Measure the length of the 4speed you have(there were several) and the length of the c6. If they are within a inch, your bronco driveshafts will probably work.
The 84 f150 pedals will bolt in the 83 bronco dash. You will have to also transfer over the hydraulic clutch master and it's components. You might have to drill a couple of holes for that, there may be some dimples already there to use for alignment.
You will have to take and drill out the frame brackets that accept the motor mounts from the f150 frame, and use bolts and bolt the 4.9 brackets into the bronco for the six to bolt in. You will also need the radiator and several other little parts from the f150.
The f150is a four wheel drive truck, so the tranny should be.
Transferring the clutch master and components(assuming dimples are there should help insure the linkages will line up alot better too.
When I pulled the motor I left the motor mounts bolted to the frame brackets so I wouldnt lose them or forget.
I knew the radiator would be different and the wiring harness once I found out its computer controlled and has o2 sensors(looked at rock auto for replacement parts and noticed), so that should be fun transferring that.
I just want to make sure I'm doing it the right way.would gearing be a factor too? I run no bigger that 33s and drive the highway a bit cause of work 50-70mph
Thanks pal
Thanks pal
From the Sticky at the top of the forum:
DSII DS-II DS2 DuraSpark II CONVERSIONS (SWAPS)
https://www.ford-trucks.com/forums/1...on-how-to.html
https://www.ford-trucks.com/forums/9...-86-i-6-a.html
https://www.ford-trucks.com/forums/1...g-harness.html
Those threads were awesome reference feel much better about it money wise, plus my bronco is 83 so I already have the harness needed
Thank you for that info!!
I looked at the granny last night when I was at the truck and it says ford Warner on it with a series of numbers that I couldn't really read/see. But the rear drive shaft is there along with the transfer case sitting on the seat of the cab.
82ford302
05-01-2006 07:17 PM
crazyjake
01-11-2006 08:27 PM
vulcan750
1978 - 1996 Big Bronco
15
05-29-2005 09:37 PM
