i found a cab off a 97 f350 clean, it had the 460 in it...would the cab work on the 97 f350 diesel frame, meaning would the electronics be the same..what about the glow plugs light that i wouldnt have on the dash and stuff like that ?
You would have to pull the harness and guages from your diesel cab and swap int the donor cab. Its not that bad but time consuming so Id recommend reference pics and notes.
