fresh 460 lacks power
Old 12-18-2014, 07:54 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
Last time I bought eight 25's there were two with loose insulators.
Almost as if the body wasn't crimped down.
Obviously those didn't work.
I too have switched to UR4's
Old 12-18-2014, 09:44 PM
Montecz's Avatar
Montecz
Montecz is offline
I have dumped a load of cash into upgrades but I have other projects that I can put the spare parts into.
Old 12-29-2014, 10:13 AM
fasthauler's Avatar
fasthauler
fasthauler is offline
Originally Posted by ArdWrknTrk
If you have a "straight up" timing set everything should be good!
I certainly would not spend the time or the $ to install a gear drive unless you just like the loud obnoxious whine.
Figure out what cam you have and check that number online to see if others report any problems.
Call the machine shop who did the work and ask them, they should have a record...
Crane has had issues in the past where cams were ground 'off time', but they won't admit it.
You say "a mild cam", I'm not sure what you are expecting.
I hate to badmouth any manufacturer, but I purchased a #353901 Grind H-260-2 cam from Crane several years’ back. The truck ran like crap. I put the degree wheel on the cam and checked the duration of the lobes. Some of them were all so far out of whack that it just didn’t make any sense. I called Crane and asked them if the cam maybe slipped while grinding and got out of whack. They called me a shade tree mechanic and that I didn’t know what I was talking about. I put a stock millings cam in and the truck has ran like a bomb ever since.
Old 12-29-2014, 12:14 PM
Montecz's Avatar
Montecz
Montecz is offline
After switching to a different brand of plugs it will smoke all 4 tires now (due to the lockers front and back) there is no lack of power or back firing anymore so I can't blame the cam, now it's just getting the timing tuned in so it starts easier when it's warmed up
Old 12-29-2014, 05:38 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Gary,
I know I'm not the only one who ran into the cam issue.
Thanks for the backup.
Montecz,
Really glad your truck is performing as expected with a simple swap of plugs!
Doesn't your ignition have cranking retard?
Old 12-29-2014, 08:33 PM
Montecz's Avatar
Montecz
Montecz is offline
Thanks, I did go through several sets of plugs which is why I thought the problem was deeper than just plugs. I just have to back the timing off, it's advanced a little too far right now
Old 12-30-2014, 03:46 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm not sure how you recurve a Pertronix distributor.
Duraspark are pretty simple, and the Crane adjustable advance comes with springs.
Old 12-30-2014, 07:33 AM
Montecz's Avatar
Montecz
Montecz is offline
The pertronix comes with different weights and springs also.
Old 12-30-2014, 08:23 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
So what is your initial, total, and what rpm is it all in?
picklebill
41
01-25-2010 09:54 PM
akaFrankCastle
06-18-2009 12:52 AM
fdude64
02-25-2008 08:42 PM
jwrboss302
09-08-2004 01:00 PM
mchild
09-12-2002 07:27 PM
Quick Reply: fresh 460 lacks power
