Pro Comp 4" Lift Coil Spring Issue
Hello everyone, having an issue with the Pro Comp 4" lift springs on my 95.
What is happening is even with the lower retainer nut as tight as can be the spring will slide off the perch and bang into my lower ball joint after driving.
To me it seems like the bend in the spring does not come around enough to retain itself.
I called pro comp but they said they have never heard of the issue.
Is there something I can do to correct it or is there a mod I can do to the perch?
Thanks.
Thanks.
I feel dumb asking this...
Spring upside down? I'm a bit rusty at the spring deal, it's been many years since I changed any out but I recall them being oriented for top and bottom...Am I wrong? Have you physically rotated them from bottom to the top to see if it changes any?
I saw SteelHorses' reply and he could be right that the spring is wrong for the application and/or vehicle
I do have an e-mail out to pro-comp but was told I would most likely not have a response until Monday.
The spring is definitely not upside down it has a flat portion up top for the retainer up there.
The part number on the spring does match the application for the truck.
Pro Comp 24413.
The truck did not have OEM springs on it when I bought it but really worn out lift springs. Those wrap around the back side of the perch and in no way can slip off towards the ball joint.
My big concern is Pro Comp really doing anything about this because I think I have had these springs for 8 months as they sat waiting for me to rebuilt the entire front end.
Was thinking maybe pro comp lift kits come with new lower mounts or something?
Pro Comp 24413.
fairfield86f150
04-13-2012 11:55 AM
macintyremustang
44
07-15-2010 05:53 PM
Huntfamily53
09-01-2009 08:11 AM
