Bad noises... '02 F250 FX4, V10
Hoping to get some ideas from the collective. I had the exhaust manifold studs replaced by a local shop 11/13, along w/ an oil change and tire rotate. On 11/17, it had snowed overnight, and my 4x4 didn't engage auto. Here's a timeline:
11/9; 154,480: Cat back exhaust system installed
11/13; 154,500: Oil change, rotate tires, replace broken studs in exhaust manifold by local Midas shop (trusted by a friend)
11/14 – 17; 154,5xx – 155,000: Hunting weekend. Did not notice anything driving to property. Monday morning driving to property, turned on 4x4, did not engage. Climate control defaulted to defrost mode. Manually lock hubs, 4x4 works, but slight crunch noise when disengaged while driving home. Approx 200 miles each direction, less than 30 miles while hunting.
11/18 & 19: Wake up to snow, manually engage hubs to get to work. Disengage when I get to the office. 4 mile one-way commute. Crunching when leaving work, but stops.
11/20: No 4x4 in morning, some noises, but not bad.
11/21-23: Parked for long weekend
11/23: Weather was warm, so tried to track down the vacuum leak unsuccessfully, but noticed that the vacuum accumulator was not fully bolted down. 1 nut missing, others nearly off. Tightened two remaining nuts. No obvious hose leaks.
11/24: Leaving for work, MAJOR crunching and shudder front end, multiple times while still in neighborhood. Seems to happen after turning, but not consistent. Leaving work for Kroger, no crunching. Backing into Kroger parking spot, light “tick, tick, tick.” Consistent rhythm with speed, can feel and hear. 1 mile home, no noise. Backing into driveway, slight ticking.
11/25: Driving to work, no noise. Slight ticking noise when slowly (idle speed) coming to traffic light to turn left.
Still locked in defrost mode. Toes are getting cold!
So, what does the collective think? Is it possible that what needed to be removed for the exhaust manifold repair could have screwed up my vacuum system, leading to the 4x4 not correctly working (and leading to a major crunch, which I assume is a hub and hopefully not the transfer case!) Or coincidence? What could the crunch be?
Thanks!
Kevin
Thanks!
Kevin
Any kind of binding in the front end driveline will cause some funny sounds. You should be feeling them big time in the steering wheel too. Even with the 4x4 disengaged, but the hubs locked, you will feel and hear some funny things driving around especially when in tight turns. Checking the vacuum lines are the first place to start. Well, actually, make sure the vacuum pump is working.
Just realized you have a V-10. No, they don't have a vacuum pump.
Last edited by CampSpringsJohn; 11-25-2014 at 09:19 AM. Reason: Correct post information
Take a look at the vacuum seals Inboard of the knuckles.
Does the axle move when you wiggle the axle shaft. It shouldn't move much if at all. If it does a vacuum seal would be a likely suspect. Pull a vacuum on it to prove it holds vacuum. Clickity crunch I'm thinking the needle bearing supporting the stub axle through the hub bearing. Dry needle bearing leads to stub axle carnage. When the hub locks are engaged the needle bearing and axle turn at the same speed. Unlock the hub lock the axle sits at rest and the needle bearing spins along with the hub bearing it is married to. Click crunch grind.
If it is this, could it have been caused by the mechanics who did the repair? Ie, if they damaged a line or didn't connect things properly, could it have caused "stub axle carnage"? Do I have any ground to stand on to have the Midas absorb some or all of the cost for this repair?
I'll head out tonight and crawl under the truck (should be fun at 30 degrees!)
Kevin
The heater goes to defrost as a default when you lose vacuum. You have a vacuum leak somewhere.
Driving with the hubs locked in should not be producing any noises. There are MANY vehicles on the road that don't use hubs; the front axles are locked in all the time. Late model Ford Rangers are a good example- the only thing that engages/disengages is the transfercase. If running with the hubs locked (but the transfercase in 2WD) causes noises, you have a mechanical issue.
My brother came home from OKC last night, so I didn't make it under the truck. Today after work.
K
Most likely, you have a hub that has debris in it, and the noises are the debris grinding against the stationary axle shaft end. Hopefully, just a hub rebuild or replacement will fix things, and the axle stub isn't hurt. I would pull it apart and check it before driving more. If you are getting noise, you are getting damage.
Finally was able to crawl under the truck w/ a pry bar. Press on the U-joint on the drivers side and everything was tight. Passenger side has a little less than a quarter inch of movement.
Is this what I'm hearing, or should I start pulling the hubs? Weather seems decent for the next few days, I won't be TOO cold working outside and I've got the time off!
So, what should I start taking apart? Any suggested "how-to" websites before I start tearing into it? I'm a capable mechanic when I have directions. Tackled ball joints once on this truck. That sucked!
Thanks!
K
Thanks!
K
Thanks!
K
Thanks!
K
