Who's the Warranty "King" these days?
Received 3,991 Likes
on
I guess it bears mention, there are different "availabilities" that I found, when shopping for ESP coverage.
Certain sources won't offer a warranty on a "used" vehicle. I think it was Flood that kicked my inquiry back, when I plugged in my info.
Other sources wouldn't offer the no-finance monthly pay option. I'd have had to pay it all up front. This was Troy, iirc, as well as my local dealer.
I finally found and settled on Ziegler Ford, fwiw. I was able to get the PremiumCare ESP coverage for 3yr/36k add'l miles at an easy no-charge 12 month pay plan. My truck had 99,995 mi on it when I had my local dealer do the pre-inspection.
To the best of my knowledge, I have not found anyone offering to extend any warranty once the powertrain 100k has passed.
so other providers will warranty anything (for a price!)
So if I am looking at this chart correctly it appears you can buy the most extensive coverage for pretty much everything that could go wrong basically an extension of the factory warranty for 8 years or 125k miles for $2,800 with a $200 deductible.
Am I understanding this correctly?
If so, to me that seems like a pretty good deal especially with how complicated these trucks are.
Now what I did not see and maybe I missed it....... I did not see a breakdown of coverage for the whole emission system..... DPF system, DEF tank,pump,sensor etc.......
Am I wrong or is there extended coverage for these items?
no DPF, but def and SCR.
https://www.floodfordesp.com/pdf/Pre...E_Ford_ESP.pdf
Air Check Valve Assembly
Air Control Valve
Air Idle Vacuum Valve
Air Supply Valve
(Hose and Tube)
Barometric
Pressure Sensor
DEF System
(Excludes Catalyst)
ECC Relay Assembly
EGR Control Valve
EGR Pressure Sensor
EGR Regulator Asy
EGR Valve Adapter
Electronic Throttle Cntrl
EVAP Vapor Storage
Canister
Idler Air Control Valve
Knock Sensor
Mass Air Flow/Intake
Air Temp Sensor
Oxygen Sensor
PCV Hose Assembly
PCV Valve
PCV Vapor Filter
Reductant Urea System
Temperature Sensor
(Engine Coolant)
Vacuum Restrictor
VAF Sensor
Variable Camshaft
That's a good point........ I am not undecided about buying an extended warranty........ I am definitely going to buy one I just think I will wait a year or 2.
I would rather pay $3k cash in a year or so instead of wrapping it into the payment...... This of course depends on how much it increases the payment.
I am headed to the dealer in about an hour to look at this truck in person and talk real numbers...... Hopefully if things work out I will be driving it hom😀
