starter problem
Old Nov 23, 2014 | 09:23 PM
Diesel wyatt's Avatar
Diesel wyatt
starter problem
i recently got an 87 ranger with a 2.9 that has an m5od in it which i know is not the correct year of tranny and the thing sounds like a tin can of rocks. it seems to me like the starter is not working properly sounds like it says on the fly wheel when its running. i don't know what year the tranny is so i don't know if i have the wrong starter but i don't think its pulling the gear back? the flywheel is perfect though. i haven't had the time to re pull the starter after it won't start anymore. just spins won't turn the flywheel. i just wanted to know if anyone had input.
Old Nov 24, 2014 | 06:54 AM
pawpaw's Avatar
pawpaw
Sounds like the internal starter bendix hardware has a problem, or may be sticking. Pull the starter, open it up & have a look. I once had to remove, open & clean my my 78 Merc Zypher starter to lube the shaft that the bendix slides on, to fix a sticking problem, where it didn't want to release enough & it would sometimes ting the flywheel after a start.
I Lightly lubed it with a film of a good quality high moly content grease & that puppy was still working fine when I finally let it go in 07!!!! Let us know what you find.
Old Nov 24, 2014 | 10:32 PM
Diesel wyatt
thanks ill have to pull it apart then.
fish-albuq
Dec 30, 2009 04:23 PM
crack
May 17, 2005 12:23 AM
BroncJMU
1978 - 1996 Big Bronco
Dec 21, 2004 08:20 PM
taxidriver
Nov 10, 2004 11:54 AM
blueovalinvestments
Sep 18, 2003 11:59 AM
