4.9 EFI Vacuum Lines Photos - Page 2 - Ford Truck Enthusiasts Forums
Old 12-27-2017, 02:25 AM
MilePostZero MilePostZero is offline
MilePostZero is starting off with a positive reputation.
Purge Cannister Line
Quote:
Originally Posted by TENNC006 View Post
At some point yes I plan to replace them all. I think I found that it went on a cooling system that sits in front of the radiator which is not hooked up?
My life revolves around aquarium work so I have a ton of clear rubber airline in a variety of sizes meant for ambient temp aquariums... think that would survive under the hood? I already made a cap out of a piece for an unused port on the vacuum tree which has survived a while.
Thanks
The line you were holding in the picture goes to your fuel tank purge canister, if you look way down low between your battery and alternator, there is a black canister, with at least two hoses connected to it, one goes to your fuel tank, the one you are holding pulls the fumes off the purge canister into the engine.
I do not think clear air tube would work for vacuum tubing, I think it will collapse, you definitely need real automotive vacuum tubing.
I am going to do a post on my vacuum line replacement, and with that I will include a schematic of the emissions vacuum system.
Old 12-30-2017, 12:43 PM
Vacuum Line Replacement
Thanks
I posted this about my vacuum line replacement, hopefully it can help you.
https://www.ford-trucks.com/forums/1...t-project.html
Good Luck
1991 Ford F-150 4.9L Vacuum Hose Replacement Project MilePostZero 1987 - 1996 F150 & Larger F-Series Trucks 3 01-02-2018 11:37 PM
85 F150 I6 need help w/ vacuum lines, choke, i.d.ing parts, etc. pd59 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 37 10-27-2017 11:38 PM
Heater issue partially resolved? Building_Fords 1987 - 1996 F150 & Larger F-Series Trucks 1 01-02-2017 02:03 AM
Here is my 302 vacuum setup...look right??? grandpas1974 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-08-2016 12:34 PM
77, 302 need pictures / help benbuilder 1973 - 1979 F-100 & Larger F-Series Trucks 6 01-29-2016 08:26 PM
Tags
4.9 vacuum lines photos
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
