clifford is getting there now.
#31
#33
Alex did 220 with similar mods but no efuel and exhaust leaks.my chip is just 50hp nothing else. It might make 275.IMO it runs about as good as one could with limited bolt on mods.we will see.it all depends on the dyno really.its a loaded type not just acclerating.I'm anxious to say the least.
Byron,I think you will like the hpop .mine pulls upstairs better now!
#34
#35
#36
#38
I checked mine Bill and its a 14 mic pre filter (33439) and 2 mic post filter (33528). They are Wix filters that were cross referenced from Bladwins that I got from Irate. I got the Wix filters from Fleetfilter.com. I haven't seen a drop in pressure yet, I change them once a year at 10 to 12K miles.
#41
on
1 Post
I set mine up to run two pumps if I need to, but I'm just running one. By "pumps" I meant the pumps I use to build my e-fuel kits. I have built 5 or 6 for myself and other people now, Byron being one of them, and he is seeing the pressure drop also. I need to figure out if it is the pump or regulator. Gotta be one or the other.
#42
#43
#44
on
1 Post
If you do, let me know what it looks like. I guess I could dig up the one I just changed out of the scrap metal barrel and cut it open.....if it's not full of water.
#45
In diesel power they did an obs buildup.the SD replacement pump wouldn't keep up ..gsl392 fixed the issue. I got mine off eBay for like 89$.
Fwiw my needle never moves though it is slightly moved since I set the pressure..I think..but that was a year ago.I guess I should put the mech gauge on it and double check.I kind of would swap my 2mic filter to 10 mic.
Glenn.what pump does Jake include?
