64 Long Tube Headers
Old 11-19-2014, 09:03 PM
Jacuzzi84's Avatar
Jacuzzi84
Jacuzzi84 is offline
Ok so I have decided to go with long tube headers for my 64 2wd. It is stock height and I don't plan on putting in any power steering. Are there any clearance issues with these reds full length at all?
Headers - Full Length for 2wd (not lowered) '54-'64 Truck [550-558] - $305.00 : Red's Headers, Speed Equipment For Old Fords
Also to ceramic coat them is very costly is it worth the money? Thanks.
Old 11-19-2014, 09:15 PM
Jim Beckers's Avatar
Jim Beckers
Jim Beckers is offline
I was considering the Speedway AHC ceramic coated headers here: 1953-1964 F100 Ford 272-312 Y-Block Chassis Headers, AHC Coated - Speedway Motors, America's Oldest Speed Shop
Under $300 shipped to your door. Let us know which way you go and update your install on the headers. Good luck!
Old 11-20-2014, 09:55 AM
sseebart's Avatar
sseebart
sseebart is offline
I got a set from Red's a few months back and they fit perfectly--well made and nice sounding. Took a little while to get them, as they had to build up a set for me.
I tried a cheaper set from Patriot first, and they didn't clear the transmission crossmember. Bought them from Summit; they were very good about taking them back.
https://www.ford-trucks.com/forums/1...0-y-block.html
~Steve
Old 11-20-2014, 11:18 AM
Shadowrider123's Avatar
Shadowrider123
Shadowrider123 is offline
Jim, I like the looks and price of the Speedway headers, but I have heard they do not clear the steering box on a 64.
Have you called and asked?
Old 11-20-2014, 05:44 PM
skidoorulz's Avatar
skidoorulz
skidoorulz is offline
First off Jacuzzi the Red's headers fit great!!!!!! But they won't come ceramic coated as you know. I took mine to a powder coater here in town and he uses something called Ceracote on headers. Said he had no come backs and have seen some of his later on and they still looked good he said. Had him do mine in bright silver and so far they still look great. About 350 miles on them and no sign of any discolorization. Ceracote does have a web site.
Jim Beckers, the speedway headers are beautiful and they are actually Patriot headers. There is 1 problem. As seeebart said they do not fit. Tey hit the trans crossmember and you can only get 1 bolt in. I had 2 sets sent to me with the same problem so I went with Red's which fit fine.
Shadowrider, with either the Patriot which is what Speedway sells or the Red's headers there is no steering box clearance issues. But there is cross member issues with the Patriot/Speedway headers.
Old 11-20-2014, 06:58 PM
Jim Beckers
Thanks for the great information Skidoorulz. I have read of some folks having fitment issues. Some people seemed to have massaged them in with a little tweaking, but I guess I will stick with my poor man's crossover eliminated/dual exhaust for now.
Old 11-21-2014, 12:37 AM
rmk73's Avatar
rmk73
rmk73 is offline
Here are the headers I have in my truck. Great price and look good. I had to notch a little bit of passenger side frame for them to fit but driver side was no issue. Probably because the perches used to put a 302 in '66 F100 move the motor over to pass side a little bit. I haven't fired the motor up yet but will in next week.
Flowtech Standard Header 12500FLT: Buy the right Exhaust Header -Performance at Advance Auto Parts
Dekoda Dale
18
08-16-2015 10:30 AM
slinginsaws
09-30-2014 08:53 AM
flipklos
08-09-2012 10:07 PM
67 429
03-23-2011 02:16 PM
79f150TX
01-29-2004 11:12 PM
Quick Reply: 64 Long Tube Headers
