Aluminum ignition switch link thingy?
I remember reading that it's a common problem so I'll assume a few here know what I'm talking about. That aluminum link piece in tilt columns that connects the ignition cylinder to the ignition switch rod and in autos locks the shifter.
What's it really called?
Anyone know if anyone is making a more durable maybe steel version?
Mine the bottom portion is broke off flush and I can't get it out, any tips, tricks?
Received 3,102 Likes
on
What I need is the best way to replace the darn thing without taking the whole truck apart. I got the part, taking one out of a parts truck, but also have to remove it in one piece. Basically do I need to take the tilt head of the column off, sure looks like I do, if so how? Pull those two theaded pins that it pivots on?
I did this once before years ago and remember thinking it wasn't as bad as everyone made it out to be, but I'll be darned if I can remember how I did it.
If you're asking about the 3E723 actuator (D1AZ-3E723-C - see pic in post 6), it's available from Ford.
Not only does it fit 1978/91 F100/350, Bronco & Econoline, but myriad 1971/80's Passenger Cars as well.
The troublesome turd isn't the actuator, but the 3B661 (E2TZ-3B661-A replaced D0AZ-3B661-A) locking lever. It's serrations wear down, causing the tilt wheel to flop around.
This little charmer is obsolete - no one has any!
on
