1995 f250 max tire size
Hello,
Next summer i want to get new tires for my 1995 F250 2 wheel drive. I want to get taller and wider tires with a good tread. I.want something that will do pretty good off road but wont be terrable on the raod. I will be putting a limited slip on it. It has the ZF 5 trans and 4.10 diff so im not worried about the truck not being able to handle the larger tires. I will be putting a leveling kit in the front and will shim the front bumber to make the clerance. So my question is with what i will be doing, what are some good tires for what im looking for? What are the largest tires that i can put on that i wont have to worrie about rubbing? Will i need new rims for the tires? Also it being a 2 wheel drive, i do see people putting more off road tires on the rear and put more road/less off road tires in the front. Are there better advantages doing this way? Also i wont be using this set up in the winter, i have a set of great blizzaks for winter.
Thanks, any information will help!
265/75R16 is wider than the stock 238/85R16 but the same height. A lot of people swap out to these. On a 2wd you can go a little taller, like a 285/75R16 but much more and you'll start having fender rub.
Go with just about anything Toyo or Yokohama has, both make great tires. I have had good luck with Bridgestone in the past as well, YMMV.
Larger diameter tires will only make your engine work harder, because they have a higher rotational inertia. If your goal is to lower your cruise rpm, switch to a taller rear gear. 3.55s were offered from the factory, and the 300 can handle that fine. 3.73s are a good compromise if you tow.
well the main goal is not to lower the cruise rpm, it would be nice but id rather have some larger tires without doing a lift kit. i do like how low geared it is untell i hit 75 mph because im running around 2600 rpm but it doesn't bother me to much. im thinking around a 33 in tire that is as wide as my 265/75 or even a little wider. i like to Toyo open country M/T 305/70r16. im thinking these on the rear and a less aggressive(cheaper) tire on the front. anyone have experience with the Toyo open country M/T?
