starting problems
Old Nov 14, 2014 | 08:38 AM
bryan sanchez's Avatar
bryan sanchez
starting problems
My powerstroke7.3 won't start it jus cranks over but if I pull start it then it fires right up however its one qt low on oil could this be my problem
Old Nov 14, 2014 | 10:05 AM
binuya's Avatar
binuya
1 quart low won't make a difference in starting. What will make a difference is if your batteries are not strong, along with the connections, glow plug system, and your starter. These trucks require a lot of juice to start. Load test your batteries to check their condition.
Old Nov 14, 2014 | 11:45 AM
bryan sanchez
starting problems
Well I haven't tested the batteries but it cranks over strong I cranked quite a few times n the battery didn't seem to be low on juice
Old Nov 14, 2014 | 11:49 AM
forfan504's Avatar
forfan504
I have same issue. Usually starts if above 15 degrees, but need block heater plugged in otherwise. Suspect bad glow plug(s)
Old Nov 14, 2014 | 11:50 AM
forfan504's Avatar
forfan504
That is 15 degrees celcius. I have had this issue in tje past and it turned out to be glow plugs
Old Nov 14, 2014 | 01:09 PM
bryan sanchez
I had it plugged in still no start unless like I said if I pull start it
Old Nov 14, 2014 | 01:45 PM
binuya's Avatar
binuya
How about your battery connections and cables. Connections and posts need to be shiny clean, and the battery cables can corrode inside the vinyl covering. A failing starter can also be a power drain. If you are able to start it by pulling it, there's something draining the needed amps to start it with your key.
Old Nov 15, 2014 | 07:17 AM
Tugly's Avatar
Tugly
The last few links in my signature have a lot of help with "cranky" engines. Give them a click - assuming you're not surfing on a mobile device.
harleymc31
32
Aug 2, 2018 04:31 PM
Joe28443
Nov 27, 2012 07:50 AM
Vince dEon
Jul 11, 2012 08:26 AM
akaFrankCastle
Jan 2, 2012 09:09 AM
n.o.yat
Oct 22, 2008 05:19 PM
