Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Anyone try an aftermarket clutch master cylinder?
Old 11-12-2014, 01:51 PM
Safooma
Safooma is offline
Safooma is starting off with a positive reputation.
Patient is a 99.5 7.3 PSD
I had the clutch pedal push rod come out of the master cylinder a few weeks ago and I understand that I will need to swap out the entire assembly to fix as they are non-servicable. I put everything back together and it is holding for now and I put two zip ties around the pedal to the cage to help keep it from coming too far back. Ghetto fabulous ;-)
Anyhow, I have been pricing complete pre-bled systems and in addition to OEM($$), I have found two aftermarket ones--a dorman and a Rhino/AMS:
Amazon.com: Rhino Pac PS0722 Clutch Master and Slave Cylinder Assembly: Automotive Amazon.com: Rhino Pac PS0722 Clutch Master and Slave Cylinder Assembly: Automotive
Amazon.com: Dorman CC649021 Clutch Combination Master Slave Cylinder Assembly: Automotive Amazon.com: Dorman CC649021 Clutch Combination Master Slave Cylinder Assembly: Automotive
Both come with everything needed(rod/bushing/start switch).
Anybody have any experience with these(or any) aftermarket kits?
Any other recommendations?
Thanks!
Old 11-12-2014, 06:19 PM
F350-6's Avatar
F350-6
F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
I've been using the aftermarket ones from Rock Auto for a few years. I replaced the first one with an OEM pre bled set up from Ford and it didn't last as long as the originals. The aftermarket ones seem to last about the same amount of time as the Ford one did, but the aftermarket ones also come with a clutch pedal position sensor so you don't have to buy that when the cruise quits working. (I've got a couple of extra of those now since I only change them when they act up)
Old 11-12-2014, 08:38 PM
Bigcat350's Avatar
Bigcat350
Bigcat350 is offline
Bigcat350 has a very good reputation on FTE.Bigcat350 has a very good reputation on FTE.Bigcat350 has a very good reputation on FTE.
I have used a couple after market separate units and had 0 problems with them.
Old 11-13-2014, 08:52 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
go with the Advance Auto one...p/n9021...its all aluminum construction versus the plastic crap.
Old 11-14-2014, 06:18 AM
1996pwrstrk's Avatar
1996pwrstrk
1996pwrstrk is offline
1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.1996pwrstrk has a great reputation on FTE.
My biggest problem with any of them has been the roll pin that holds the line at the slave cylinder , they keep falling out . I tried glue , and RTV , this time I safety-wired it. Tim I wish I would have known about the aluminum one I just changed one last weekend .
Old 11-14-2014, 05:00 PM
Safooma
Safooma is offline
Thanks for the info. I'm in Oregon and we don't have advance auto out here. I may order it from them online though.
Old 11-14-2014, 11:17 PM
timmyboy76's Avatar
timmyboy76
here's where i got mine. 1yr warranty
http://www.ebay.com/itm/Perfection-Clutch-PF9021-Clutch-Master-Slave-Cylinder-Assembly-/271652040519?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f3fb92f47&vxp=mtr
scottddove
196
12-01-2016 03:38 PM
Kumrow99
03-04-2016 07:58 AM
Sous
13
02-26-2016 01:02 AM
CPB1
11-19-2015 10:57 AM
Mikey_23_ny1
1968-2013 Full Size Vans
04-14-2015 05:29 AM
Quick Reply: Anyone try an aftermarket clutch master cylinder?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
