Ignition Module Move
Have you ever heard the stories about the ignition module going bad and wondered why? Pull over after driving for an hour on a hot day and put your hand on the module. You will pull back with some burnt fingers. That module is filled with semiconductors and their main enemy is heat.
I got tired of looking at the rats nest of wires under the hood and the premature failure of the ignition module, so I decided to move it inside of the cab. It is a simple matter of unplugging the wires from the wire harness under the hood and pulling the harness back inside of the cab. The firewall grommet releases by squeezing it down from the engine compartment side and pushing it back through the firewall. Remove enough of the wrapping from the harness to locate the wires to the module connectors, cut them near their centers so that you have enough working room to splice them back together and pull the wires back through the firewall grommet. Splice them back together with additional six inch long pieces of wire. Solder the splices and insulate them with shrink tubing. (This extends the connectors long enough to give additional mounting flexibility) Pull the wire harness back into the engine compartment; snap the firewall grommet back into place and plug every thing back in. You now have the module connectors inside of the cab and extended an additional six inches. Move the headlight dimmer switch an additional 1-½ inches further away from the kick panel and mount the ignition module to the kick panel just under the fresh air intake duct. (You may have to move the emergency brake pedal over to clear the module) The truck should start right up if you wired the connectors correctly. The module will stay cool to the touch from now on.
This project is not for everyone, but if you want to clean up the underhood wiring and protect the module from excessive heat then this project may be for you.
The following users liked this post:
Should be plenty of room to the right and above the fuse block. May complicate changing it out though. Working up there is a pain.
There has been some positive reaction to my project. The module could be mounted anywhere inside the cab that is convenient. The idea is to get it out of the engine compartment. I don’t think people realize how hot it gets inside of the engine compartment. The 460 creates a lot of heat and it is even greater if headers are installed. I don’t think venting the module is going to do much if it is still in the engine compartment. Also remember that the module needs to be mounted on a mental surface. This works as a heat sink for the module.
I know, an old thread here ... but then I just found it, at least I don't recall it. I am reminded of how my Dept. garage took to relocating a "lean burn" computor from the air cleaner side into the passenger side dash in the car to fight the same issue .... heat.
I was going to build a deal to lift my DS box off the apron surface there near beside the exhaust, to shield it, to turn it open side up so any potting stays inside .... but this looks interestingly better. Could still mount it open side up, but under my dash, out of the engine compartment.
I've only had one fail, it was the original, failed maybe 10 years ago, but cooling with cold drink got me going. My spare stored in the truck behind the seat was thankfully in a box, as it's potting had got hot enough to run out inside the box behind the seat, just from summer heat buildup. It had never even been used, but it works still (I tested it) and I have a second new in box one, stored open side up in its box. The one I have now under the hood was bought new too, and so far is good.. I would not move and remount one in a position where hot summer heat might lead to soft potting on my floor or carpet ... or my boots.
I'll revisit this when Spring finally starts for sure.
When that potting melts is can be a GIANT PITA to get it off the dvrs inner fenderwell. Just add a couple of washers to space it off the inner fenderwell and go. Same for when you fry your voltage regulator due to a faulty battery cable. There is a potting in that too and it stinks to high heaven for a while and that stuff is also hard to get off the passenger side of the inner fenderwell.
I think that the potting is just a means to prevent vibration damage ... and that the internal components might actually run cooler or even last longer without the potting ... if otherwise insulated from vibrations? I wonder if a good ground wire to a mount a hole and using a couple bungie cords to suspend the box in free air or in front of a vent ...? It isn't the movements of vibrations that can harm electronics as we are all moving all the time here on Earth ... rather it's the rapid & repetitive sharp stops and reversals of movements of vibrations that I'd say harm electronics.
Like shaking your head to indicate "NO" ... or turning it to look at Barbara as walking by ... doesn't hurt unless your head hits an overhanging Bunson burner shelf on the cinder block wall next to you in science lab .... those shelves did not move (our school had one on each of the little shelves about 5 feet off the floor, an instructor could tell at a glance if one or more was not back on it's shelf, unhooked, not lit). Just the memory still hurts 55 years after ... but I'm still here ... and I have no idea of where she is these days as her folks sold the motel and drive inn theater and they all moved away.
I did long ago replace my '77's mechanical VR with a solid state type VR as used on some later Fords. It (mine) mounts up on the radiator support, on the right, near the battery too. I never heard of one leaking in normal service as likely they run cooler I guess. I guess a bad cable could maybe overwork it though?
LARIAT 85
38
01-09-2016 12:48 PM
Splash78
07-13-2007 09:07 PM
