1950 F1 Paint Detail
Have disassembled and begun degreasing and media blasting my F1. It will be time to start painting the parts and pieces soon. During this adventure I found a bit of gray paint hidden on the underside of my hood hinge. Does anyone have a paint code for the ford color used on the hinges? We're any other parts painted with this color?
Also, is there any info on the paint detail for the F1 chassis and under the hood?
Thanks!
Thanks!
These were work trucks for the farmers and tradesmen returning from the war built as quickly and cheaply as possible. Ford was not concerned about color aesthetics. AFAIK anything that wasn't painted body color was painted black, the cheapest color paint with the best and easiest coverage.
The fender size or wheel opening was determined by the tire size.
I have read here multiple times it was based on truck size but this makes sense too. This wasn't the only guy who has told me similar stories of assembly line workers adapting or improvising, especially in this time period, to get the job done.
Most 1948-52 hood hinges were left in the dipped grey primer/topcoat, but some were black, and some were body color. Most hood spring assemblies were body color, but some were left grey, and some were black.
Most radiator supports were left grey, but some were black.
While we're at it, most 1948-50 seat frames were left grey, but some were the same brown color as the sunvisor brackets.
Most 1948-50 gas tanks and tool trays were body color, but many were the same brown color, but not necessarily in the same truck! I have found many brown tanks with body color tool trays, and at least one the other way around.
Chuck
Chuck
I don't know how I missed this thread. When I rebuilt Blue, my 1949 F4, I did not paint the hood hinges or spring assemblies, just cleaned and lubricated them. AFAIK the gray coating is original as the truck showed no signs of ever being messed with. What you see here is the original gray
1950f1ca
02-12-2017 08:01 PM
brider
16
03-15-2011 12:54 PM
dagwood387
16
04-17-2010 09:27 PM
