E fan help with motor swap
So I just did a mark viii swap into my 98 expedition.everythings running good.I decided to use a efan the one I chose is off a 03 windstar it's dual fan that covers the whole radiator and bolts to rad at shroud holes.I don't know if this is enough cf cause the windstar is a v6.I'm running summit racing fan controller adjustable 160 to 240.What temp should it be set at with a radiator probe??I'm running still running the stock thermo think rate is190.Any help or advise with efan use.
Thanks for reading
Thanks for reading
MojaveMuse
04-14-2017 01:14 PM
4 rings
10-18-2013 11:53 AM
Ford Truck Racer
08-02-2002 05:30 PM
