1962 4x4 Horn and Tun Signal Needs
Old 10-23-2014, 01:10 PM
624WD's Avatar
624WD
624WD is offline
I need to rebuild what is left of the upper steering column on my 1962 4WD F100.
It is missing everything but the steering wheel and nut.
Can someone help me out with a parts diagram for the turn signals and the horn assembly? and, or, have parts I can use to restore it?
It currently has a three spoke 17" steering wheel and I am wondering if that is the original steering wheel too. ? Any pictures, diagrams, parts, is appreciated. thank you.
Tom
Old 10-23-2014, 03:30 PM
scottlathrop's Avatar
scottlathrop
scottlathrop is offline
The 17" wheel is probably right. Attach a picture of what you have and there are a raft of members here that will help. Mine is a 66 so I don't want to steer you wrong. Wow that was lame
Scott
Old 10-23-2014, 03:39 PM
TA455HO's Avatar
TA455HO
TA455HO is online now
Tom <a href="mailto:rvrwood@hotmail.com">rvrwood@hotmail.com
61/65 F100/250 (4x4), F350, 66 F250 (4x4) used the 18" 4 spoke steering wheel.
C1TZ-3600-A (Black)
C1TZ-3600-B (White)
If you run a 3 spoke 17" wheel, you will also have to change the horn button, use the 17's horn brush/insulator and probably the T/S switch as well.
The 18" wheel & 4WD related parts are not the same.
Old 10-23-2014, 03:54 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
I need to rebuild what is left of the upper steering column on my 1962 F100 4WD.
It currently has a three spoke 17" steering wheel and I am wondering if that is the original steering wheel?
No, it's not. Original wheel has 4 spokes .. 18" diameter.
4 spoke 18" diameter steering wheel: 1961/63 F500/750 - 1961/65 F100/250 4WD - 1961/66 F350 - 1966 F250 4WD
Originally Posted by TA455HO
If you run a 3 spoke 17" wheel, you will have also have to change the horn button, use the 17" horn brush insulator and probably the switch.
4WD's didn't use a 17" wheel, but all the other related horn & T/S switch parts were used with both the 17" & 18" steering wheels.
So...this means that the OP does not need to change the 17" wheel.
1961/65 F100/250 4WD - 1961/66 F350/1100 - 1966 F250 4WD:
C2TZ-13341-D .. T/S Switch / Obsolete
MCDONALD OBSOLETE PARTS CO. in Rockport IN has 1 = 812-359-4965.
COLLECTORS AUTO SUPPLY in Oroville WA has 2 = 800-414-4462.
MUSTANGS ETC in Van Nuys CA has 3 = 818-787-7634.
C1TZ-13A805-D .. Horn Button / Obsolete
MCDONALD OBSOLETE has 1.
WESLEY OBSOLETE PARTS in Liberty KY has 7 = 606-787-5293.
PARTS INTERNATIONAL in Farmers Branch TX has 9 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 79 = 800-543-4959.
C1TZ-13A807-B .. Horn Button Spring / Obsolete
WESLEY OBSOLETE has 1.
MILLER OBSOLETE PARTS in Binghamton NY has 2 = 607-722-5371.
GREEN SALES has 16.
COAF-13A821-A .. Horn Brush / Obsolete
MCDONALD OBSOLETE has 3.
KLIMESH MOTOR SALES in Calmar IA has 14 = 563-562-3241.
WESLEY OBSOLETE has 22.
C1TF-13A822-A .. Horn Brush Insulator / Obsolete
KLIMESH has 1.
MCDONALD OBSOLETE has 6.
PARTS INTERNATIONAL has 10.
Note: In pic at left, 13A832 located below steering wheel was only used without turn signals.
Old 10-23-2014, 05:49 PM
TA455HO's Avatar
TA455HO
Just quoting you there Maestro. So you just huh'ed yourself 3 times there. LMFAO.
https://www.ford-trucks.com/forums/1...l#post11381376
Old 10-24-2014, 06:53 AM
624WD's Avatar
624WD
624WD is offline
Fantastic! This is just what I needed! Thanks. Tom
Old 10-24-2014, 09:26 AM
schoo's Avatar
schoo
schoo is offline
I got a turn switch from the mustang outfit last year, a lot of money not many of these around
Good luck
KDeYoe
11-12-2016 02:25 AM
Shadowrider123
05-01-2014 06:43 AM
kjhales
03-30-2013 06:31 AM
Shadowrider123
22
02-27-2013 12:40 PM
OldHarley
10-26-2009 05:12 AM
Quick Reply: 1962 4x4 Horn and Tun Signal Needs
