tow capacity of a 1992 f 250 - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Old 10-22-2014, 01:35 AM
Bob roll Bob roll is offline
Bob roll is starting off with a positive reputation.
Hi can anyone tell me the tow capacity of a 1992 f 250, or gcm.
Bob
Old 10-22-2014, 12:27 PM
BigF350 BigF350 is offline
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
It really depends. Do you know what engine, what transmission and what rear end ratio was fitted?
It also may depend on whoever imported/converted the truck, as to what rating they issued with the truck, and if it differed from the rating put on US trucks (for imported trucks, typically it doesn't).
The answer to these questions may not matter, as even in its lowest tow rating configuration, it should pull 3200kg - the highest tow rating configs are around 5000kg.
Old 10-22-2014, 03:41 PM
It has a 351 windsor a c6 not sure of diff ratio, thank's for the reply.
Bob
Old 10-22-2014, 04:15 PM
Old 10-23-2014, 04:15 PM
Thank you for that, I wonder if that would apply to aus or only the usa.
Bob
Old 10-23-2014, 04:31 PM
The vehicles are mechanically the same, and it comes down to how whoever sold your vehicle originally rated it.
All private importers I have seen have just used the USA tow ratings.
The Trucks sold by Ford Aus were downrated a bit.
Frankly, it doesn't matter, Police Officers/registration authorities have no way easy way of knowing what the towing capacity is of a 92 F250 unless it is stamped on it. The main things they will care about is if its above 750kg, the trailer has brakes, and if its above 4500kg, you have a truck license that allows that weight.
Old 10-23-2014, 10:46 PM
Thank you, I suppose if it had a rating on the tow bar they would be happy with that.
Bob
High capacity Fmc4lfe 2017+ Super Duty 4 04-22-2017 12:02 PM
Differences Between a 1990 and 1992 4.9L Straight 6 Bob Shumway Ford Inline Six, 200, 250, 4.9L / 300 1 10-09-2016 10:46 PM
Rated towing capacity 96 f250 diesel? automaticlee 1987 - 1996 F150 & Larger F-Series Trucks 5 10-05-2016 08:38 PM
1992 f-350 Towing Capacity? daddylee100 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 4 06-17-2013 06:48 PM
2000 F250 crew V10 4.30 limited tow capacity? alexisdakota 1999 to 2016 Super Duty 3 01-26-2005 08:45 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
