Terminator and t56 swap into 56 f100 - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 12-27-2014, 06:10 PM
FastFred68
FastFred68 is offline
FastFred68 is starting off with a positive reputation.
  #32
Old 12-27-2014, 06:11 PM
FastFred68
This was a burn out with the old 351w and c4 combo. 1st and 2nd gear on the line lock. lol
  #33
Old 01-13-2015, 08:21 PM
FastFred68
Finally got the cobra pedals and hydraboost. Hopefully I will have them installed by the end if the week.
  #34
Old 01-13-2015, 08:25 PM
FastFred68
Steeda aftermarket pedals and quadrant.
Hydraboost with lines
  #35
Old 01-14-2015, 09:47 AM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
drptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud of
what is the hydroboost out of? Looks like a nice compact unit.
  #36
Old 01-14-2015, 11:37 AM
jrockdiddy's Avatar
jrockdiddy
jrockdiddy is offline
jrockdiddy is a splendid one to beholdjrockdiddy is a splendid one to beholdjrockdiddy is a splendid one to beholdjrockdiddy is a splendid one to beholdjrockdiddy is a splendid one to beholdjrockdiddy is a splendid one to behold
Subscribed
  #37
Old 01-14-2015, 12:44 PM
FastFred68
The hydraboost is out of the 03, 04 svt cobra.
  #38
Old 01-16-2015, 03:11 PM
FastFred68
Got the hydraboost mounted. We put a piece of 1/8" plate between it and the pedals for strength
Pedals mounted. Still working on the throttle pedal. Time to order the clutch and throttle cables
  #39
Old 01-26-2015, 06:19 PM
FastFred68
I modified the transmission cover to fit the t56. It will eventually be covered in dynamat
  #40
Old 01-26-2015, 06:21 PM
FastFred68
The drivers side header has been modified. The steering shaft will be centered when finished
  #41
Old 01-26-2015, 06:25 PM
FastFred68
Steeda quadrant, firewall adjuster, and adjustable clutch cable. Also throttle cable and yoke for transmission.
  #42
Old 01-26-2015, 06:26 PM
FastFred68
Almost time to take out the engine and finish the firewall and touch up the frame
  #43
Old 03-22-2015, 09:55 AM
mustangmike6996's Avatar
mustangmike6996
mustangmike6996 is offline
mustangmike6996 has a good reputation on FTE.mustangmike6996 has a good reputation on FTE.
Any updates?
  #44
Old 03-23-2015, 09:57 AM
FastFred68
Started welding up the un used hoes on the fire wall
  #45
Old 03-23-2015, 10:14 AM
FastFred68
Pulled the valve covers to check out the top end. Looks great
Checked the bearings to make sure everything looks ok. It looks like the previous owner upgraded to arp rod bolts. Score
Quick Reply: Terminator and t56 swap into 56 f100
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
