Radio Delete Plate C7TB-8104371-AW
would not mind a nice new one, but at $35 for them, I will hold off.
WRONG 67 radio opening is smaller then the 68-72 there was 2 different delete plates for this generation truck 67 ONLY and 68-72
Originally Posted by hillcountryflt
I think it was just the k****/bezel that were different on a 67 radio, but the opening was the same.
Applications: 1967 F100/750.
The dash, radio and heater are 1967 only .. not the same as 1968/72.
The doors are 1967 only .. as is the firewall, brake & clutch pedals, ignition switch, brake light switch, grille and a whole plethora of other parts.
1967's look the same as 1968/72's, but looks can be deceiving.
Incorrect.
Marked with ID engineering number: C7TB-8104371-AW = Ford part number: C7TZ-8104371-A .. Instrument Panel Radio Opening Cover / Obsolete
'67 radio block off plate
Hello all, First post as I just bought a '67 F100. The question that I have is my C7TB-8104371-AW block off plate fits the dash holes but sits out about a half inch from the dash. Not sure what is going on. The dash looks all stock and not modified in any way. Any help would be appreciated. Thanks Doug
I have never seen one 1st hand but I assume the block off plate is mounted with the same two tabs that mount a radio. If this is correct then your PO (previous owner) prolly moved those tabs forward to mount a radio in the past.
