Back up light socket
Old Oct 16, 2014 | 02:21 PM
oft's Avatar
oft
Hey all,
The socket for my reverse lights is only supplying 9 volts. Unfortunely, I cant find one. The bed is a 78, the socket has 2 wires for an 1156 bulb. I can only find the 3 wires socket (for the brake lights). Anyone know where I can get a reverse light socket??
Thanks!
Old Oct 16, 2014 | 10:10 PM
jtindale's Avatar
jtindale
Originally Posted by oft
Hey all,
Thanks!
You should be able to find those at most parts stores. I think I bought mine from O'reillys.
Old Oct 17, 2014 | 07:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The socket for my reverse lights is only supplying 9 volts. Unfortunately, I can't find one.
Same tail lamps & sockets: 1974 F100/350 Stylesides from serial number T80,001 - 1975/79 F100/350 Stylesides - 1975/91 Econolines - 1978/79 Bronco's.
Old Oct 17, 2014 | 07:53 AM
oft's Avatar
oft
Well, I cant find any for my 76 (which actualy has a 78 bed) However, a socket off a 74 Ford car (Montego I think) will fit. I hope. I'll see tonight as a dealer here had one that I'll pick up after work.
Old Oct 17, 2014 | 08:01 AM
NumberDummy
Passenger Cars do not use the same backup lamp sockets. The correct socket is plastic and twists into the one piece molded plastic tail lamp assy.
I already told you (in post 3) which vehicles use the same tail lamps and sockets. Here's the backup lamp socket by itself:
D4TZ-15536-A .. Backup Lamp Socket with pigtailed wires / Obsolete
Applications: 1974 F100/350 Stylesides from serial number T80,001 - 1975/79 F100/350 Stylesides - 1975/91 Econolines - 1978/79 Bronco's.
How many 1975/91 Econolines are there in local wrecking yards?
Here's the individual tail lamp socket, it was also used on some Passenger Cars as the park lamp socket, ditto for the F100/350's, Bronco's & Econolines:
D1FZ-13234-A .. Socket with pigtailed wires / Obsolete
1974 F100/350 park & Styleside tail lamps from serial number T80,001 / 1975/79 F100/350 park & Styleside tail lamps - 1975/91 Econoline park and tail lamps - 1978/79 Bronco park & tail lamps.
1971/73 Mustang & Pinto park lamps / 1973 Torino/Ranchero park lamps / 1975/78 LTD park lamps / 1976 Pinto park lamps.
Old Oct 17, 2014 | 09:14 AM
oft's Avatar
oft
Yes, I realize that you told me what socket will be a direct replacement. however, I was unable to get it here. And I realize the passenger car one is not an exact replacement. However, the PN I am looking at (and I dont have it on my now) shows a socket that has the same type of tabs and will (hopefully) screw into the lense. Since I already ordered it I'll see if it fits. If it doesn't I'll google search the PN you listed and see where I can get it.
No, I haven't tried a wrecking yard yet, I'm sure i would probably find one there but I have not had time to go look.
Old Oct 17, 2014 | 09:47 AM
NumberDummy
D4TZ-15536-A .. Backup Lamp Socket / Obsolete
OWEN FORD in Jarratt VA has 1 = 434-535-8515.
EARL FLOYD FORD in Carrolton KY has 2 = 800-732-2037.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
MILLER OBSOLETE PARTS in Binghamton NY has 4 = 607-722-5371.
POECS PARTS in Erie PA has 5 = 888-864-9305.
PARTS INTERNATIONAL in Farmers Branch TX has 9 = 888-727-0418.
Old Oct 17, 2014 | 10:10 AM
oft's Avatar
oft
Wow - I wish I had your resources! I had hit a few Ford dealers, Advance, NAPA and Rocks - nothing.
I'll be bookmarking this post
Thanks!
Old Jul 10, 2016 | 08:54 PM
robbray85's Avatar
robbray85
Adding this for future viewers, I picked up these GM plugs and they fit my 76 Ford F150 with slight modification. Just pinch off the 3 metal barbs, xacto blade the tailight a little and you'll have a snug fit
http://m.ebay.com/itm/1156-Bulb-Socket-Single-Contact-Back-Up-Cornering-Turn-Signal-76-87-GM-215-/141450566098?txnId=1286562941004
#1156 Bulb Socket Single Contact Back Up Cornering Turn Signal 76-87 GM #215
Old Jul 10, 2016 | 08:57 PM
robbray85's Avatar
robbray85
Old Jul 10, 2016 | 09:44 PM
robbray85's Avatar
robbray85
Old Jul 11, 2016 | 06:20 AM
DB429SCJ's Avatar
DB429SCJ
NAPA # LS6459 Listed for Ford car but fits perfect.
LCA078
17
Oct 23, 2015 11:43 AM
Boba Fett
May 22, 2011 01:25 PM
the Goat
Oct 14, 2007 06:38 PM
stroken
Jul 25, 2007 11:20 PM
oldhalftons
Electrical Systems/Wiring
Mar 30, 2005 10:06 AM
