What to do with virgin 01? Look Tugly - Page 24 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 02-13-2018, 08:26 AM
Walleye Hunter
Walleye Hunter is offline
Walleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to behold
I'm an advocate for just buying new rotors over turning them anyway. First off they're really not that expensive and you do have to pay to have them turned, secondly after they're turned they don't seem to last long, thirdly there is less downtime with just throwing new ones on there.
  #347
Old 02-13-2018, 10:53 AM
brian42's Avatar
brian42
brian42 is offline
brian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud ofbrian42 has much to be proud of
I do the same now too. It was a different story with my 2wd F-150. The hub and rotor was one assembly making the price considerably more so I turned those until minimum spec before I'd buy another one.
  #348
Old 02-13-2018, 07:48 PM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
Yes, this and my X being 2wd's we put off rotors for quite awhile as they are I believe more than twice as much as a 4x4 rotor. Lately with cuts to costs I only seem to be able to get one cut out of rotors then they go under spec. I have heard of some cheap rotors strait out of box being right at spec already.
BTW minimum tolerance is 1.417".
But yes, I typically replace the rotors when they are reasonable any time I am doing brakes. In fact many times I will replace the calipers as well as they are also usually cheap.
  #349
Old 02-13-2018, 08:06 PM
z31freakify's Avatar
z31freakify
z31freakify is online now
z31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to beholdz31freakify is a splendid one to behold
Another thought is buying new rotors, then get the old ones resurface and store, them for next go around. I have lots of set for the fleet ready to go for when they need brakes.
  #350
Old 02-14-2018, 08:12 AM
Snowseeker's Avatar
Snowseeker
I did/do have a small stockpile of certain parts for the OBS trucks we have as they all use the same parts. This is the only superduty we have so far and everything I have replaced on it has been junk so I haven't saved much for it yet. But I am sure things will gather over time.
I have so many caliper clips from the earlier OBS trucks. Those things used to loosen up and the caliper would start to clap all the time. We don't have any trucks that use those any more, I suppose I would toss them.
COsby
1999 to 2016 Super Duty
01-25-2018 09:52 AM
bbex
21
12-11-2017 07:44 PM
JocelynMarquez64
06-13-2017 06:32 PM
johnl2
04-29-2017 11:06 PM
IDIoit
03-07-2017 10:16 AM
Quick Reply: What to do with virgin 01? Look Tugly
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
