292 questions
Old Oct 11, 2014 | 08:45 PM
newguy399's Avatar
newguy399
292 questions
Hey guys might be buying a 292 out of a 66 ford pick up and don't really know anything about it,guy says it turns over nicely and has 74xxx on it, its going in a 56 f100.can u guys tell me bout it, thanks
Dan
Old Oct 11, 2014 | 09:03 PM
85e150's Avatar
85e150
Can't tell you anything except the 292 was not offered in '66, so be sure of what you are getting.
Old Oct 11, 2014 | 09:20 PM
newguy399's Avatar
newguy399
My bad ment to say 1963
Old Oct 11, 2014 | 10:12 PM
HT32BSX115's Avatar
HT32BSX115
Dan
Howdy,
"Turns over nicely" doesn't really say much. Any junk-yard engine will do that.
If you want to be able to run it with little or no problems, you'll want to do a compression check and pull the valve covers so you can look for evidence of oil on both left and right rockers.
I would pull the dist and turn the oil pump with a drill. Then I would slowly turn the crankshaft and look for oil pressure to the rocker shafts. (if it has a cross-drilled cam you have to turn the engine slowly to find the point at which the oil flows to the rockers shafts.)
For the compression check, you might also do a leak-down check so you can see if the valves or rings are leaking excessively.
You also might have a look at where the water pump will center on the radiator.
If you need to put a high mount pump and fan on it, you may have problems finding a suitable one if you don't already have one.
That 56 (if it was a V-8) likely came with a 272. The 292 will work fine.
Regards,
Rick
Old Oct 12, 2014 | 10:54 PM
newguy399's Avatar
newguy399
Thanks guys I called him today to talk about it, turns out he builds old hot rods and is building 3 f100s,yada yada yada.he fired the motor up and it died, belives the distributer is bad. Thanks for the info guys
Bigfatsteve
Apr 14, 2014 09:53 AM
spquint
1983 - 2012 Ranger & B-Series
Mar 4, 2007 06:41 PM
fordeverpower
Aug 30, 2005 04:58 PM
bigvinnie
Mar 27, 2004 06:44 PM
inliner
Feb 1, 2003 04:43 AM
