No, it’s probably a 16” since it has the Firestone RHP rim. Also you can almost see the lower loop of a 6 on the 7.50-16” tire. It has innie hub cap mounts so it’s likely an early 16” x 5.50” that was a heavy duty wheel available for later 3/4 tons. If there’s a number I’ll look it up, but if it’s a KH there won’t be a number. Stu
