Heater Plug in Bumper - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-11-2014, 01:18 AM
polosabre's Avatar
polosabre polosabre is offline
polosabre is starting off with a positive reputation.
Has anyone tried installing a plug in your front bumper for your block heater? I just installed one in mine for the heater and another one for an onboard charger. What do you think?
This is for the heater and one on opposite side for charger.
I mounted the charger to the fender well.
Old 10-11-2014, 02:04 AM
Ltngdrvr's Avatar
Ltngdrvr Ltngdrvr is offline
Ltngdrvr has a good reputation on FTE.Ltngdrvr has a good reputation on FTE.
Oil heater? Not a block heater like from the factory?
And having them in the plastic air damn leaves it awfully vulnerable, way too easy to get damaged.
Old 10-11-2014, 07:55 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I would move it. Why don't you use the block heater?
Old 10-11-2014, 08:50 AM
Big-Foot's Avatar
Big-Foot Big-Foot is offline
Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.
Beings how the OP is in SC and not in the Snow & Salt belt like I am, it will probably be just fine.. But yes, when down low like that, it would be subject to more damage from other road debris. I was thinking about doing something similar but putting it behind the license plate. I would get a fold down license plate bracket like I have on the read of my 69 Camaro since it is spring loaded..
The only other bad thing about having the plug in down low is "out of sight - out of mind"... I'd probably forget I had it plugged in and drive off with the cord still connected. I have draped the extension cord from my shop over the drivers side mirror as a reminder..
Old 10-12-2014, 02:41 PM
Husky44 Husky44 is offline
Husky44 is gaining momentum as a positive member of FTE.
Never went to that much trouble. I just ran it to the inside of the front bumper and wire tied it so I could reach through the opening and pull 6-12" worth out so I could easily plug in with extension cord. I also kept an inline light on my plug, so I could see for sure that juice was flowing. Mine was plugged in every day for about six months, so it was more of a habit to unplug than to not unplug, but the extension cord across the DS mirror is a good technique to ensure you don't forget and drive off.
Not sure why the OP chose oil heater (pan?) over block heater? Block heater is much more effective, and not that difficult to install.
my bumper build 7.3 forever 1994.5 - 1997 7.3L Power Stroke Diesel 29 08-03-2017 04:56 PM
AC and Power steering/Alt. brakets z31freakify Ford Truck Parts for Sale 0 08-09-2016 10:00 AM
Heater control knobs blsd49 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 08-01-2016 09:50 PM
2008 F-350 LED Pod Headlight Build thegenco12 Appearance & Dress-Up 1 07-06-2016 10:30 PM
5.4 Factory Intake Manifold 04mudslinger Ford Truck Parts for Sale 0 04-08-2016 08:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
