How large of a jack for tire change on a Powerstroke? Floor jack or Bottle jack?
I am in need of a jack to change a tire on my Powerstroke. Being that I will be lifting just one tire/wheel at a time, how large of a jack do you think will work? And would you go bottle jack or a floor jack?
on
My answer was based on portability for roadside emergencies. I keep it in my truck bed tool box. For garage use, I have a 2-1/2 ton and a 4 ton floor jack, along with (4) 3-1/2 ton jack stands.
Received 3,090 Likes
on
I also am only talking about emergency use. I use a 3 ton jack with 6 ton jack stands in the garage. I measured from the axle tube to the top of the rim and it's only 6 1/2" so I stayed away from the bottle jack, thrones I saw were 8 1/2" collapsed. I am gonna get a small 2 ton floor jack for the toolbox I guess.
I still carry way too much junk left over from my SAR days so I have one 20 ton, two 12 ton, a 6 ton jack stand and the stock under the back seat. I have two 12 ton as one is for tire rotation and the other for flats (much easier). Here is the high 12 ton: http://usjack.com/products/High%20Ra...le%20Jacks.pdf (neighbor borrowed it and I better get it back) a little pricey but they are rock solid, extra wide bases and made in the USA
