Big boy truck info...help educate me.
Ok guys. I've been searching all over the place and have found some info but not many specifics. I posted in a different thread a couple weeks ago about some of the larger trucks and I would like you guys to help educate me on these. I know we all like talking so here's your chance. I've seen many times people saying get rid of the "widow makers" but I'll be honest, I don't know if any of these trucks have them. So I googled "ford f5" and came up with these pics. Not all are F5's I don't think but again you guys can tell me. I put a little info on each pic but if you guys will, put me a little info under one or all of the pics and tell me exactly what I'm looking at. I'd like to know more about the bigger trucks because I may end up having to sell my truck to build me a little house. Instead of buying another F350 powerstroke like I used to have, I thought when the time came to pull something I'd go the old truck route. I just don't for the life of me see how they pull with the same flathead I have or even the flat 6?????? We are talking 100 hp. Lots I need to know so fire away. And thanks for the help!!
Just for info purposes I'm looking at building me a "tiny house" to live in. I've been in the Architecture business all my life now and am very interested in these. I will not be pulling this thing all over the place like an RV. I would however like to be able to pull it say 2-3 hours (roughly 200 miles) to the beach once or twice a year for a weeks trip. It's all flat down here so giant hills wouldn't be a problem. I would also like to turn this into a new business venture for myself. The models below are what I've been working on using Sketchup. I'm still working on it so its not quite finished yet. Creating 3D models and construction drawings are part of my thoughts on the business as well as constructing them for people.
This is one of my favorites. Great color combo and like the wheels.
I really like the short stubby look. It's kinda tall though and looks like it may be on a different chassis???
Love the colors on this one.
Beauty but too long for me.
Agian I like the shorter looking chassis.
Like all of this one except the dump bed wouldn't be for me. I'd rather have a flat bed on it.
Very cool COE. I wouldn't need that type of hitch.
This is a nice looking truck but I'm again confused on what chassis/wheels those are.
My other favorite. This would be perfect.
My proposed design of a 24' tiny house.
I cut a partial section thru so you all could see inside. It's small but it beats what I have right now which is nothing.
Close to what I'm hoping to build. I do not know those people.
If I am reading you right, you have two basic questions.
This picture clearly shows the raised band on the concave side of the Widowmaker. It is the identifying feature that stands out. I see the widowmakers on some of the trucks and some are not possible for me to ID.
Pulling a trailer. These old truck will pull it if you have all the horses working. They will not pull a sizable trailer fast. It is all about gearing. With gear ratios in the 5:1--6:1 range it is just not going to be very fast. These trucks had GVWRs of between 10,000 and 16,500 lbs and then if you get into the Big Jobs, the GVWR goes up more. I did not see any widowmakers on the Big Job trucks you show.
Hope this is the kind of information you seek. Sounds like a plan.
Agree, most of the F-5/6s have widow makers, at least from what we can see from the pics. The F-7/8 has Dayton style "demountable" wheels with Goodyear style split side ring/locking ring outer rims.
Modern roads and traffic make use of older big trucks a challenge. Slow acceleration from a stop achieving road speed, top speeds less than demanded by moden traffic, and brakes designed for the conditions of an old era will make you a rolling road block. Occasional use off major roads would be my view. Stu
What they said. ^^
Most of the "too long" beds are the 12 foot beds and longer wheelbases, and the "shorter" ones you like are the 9 foot beds. Looks like those "tall" trucks are 4WD, possibly Marmon Harrington.
The 226 I6 flathead has only 95 hp but has 185 pounds feet of torque at 1500 rpm (for 1951). Ford Flathead Six 1949 to 51
Trust me when I tell you that you can pull stumps with it. But top speed is about 45mph.
The F4 is normally the 9 foot bed and shorter wheelbase truck of the duallys. Mine has the 10,000 pound GVWR upgrade. I don't know if you could get the F5 and higher with a 9 foot bed.
What they said. ^^
on
My point though was to get info on the F4's and F5's mainly. I was hoping someone would give me what all was available when (engines, trannys, rear ends, cab/chassis, dual rear wheels, etc).
on
I am pretty sure you could re-gear the the drive axle
and get 55 or 60 with the flat motor. As you said most
of the roads you will be on going to the sunny beach are
flat. A duel res master cyl. and trailer brakes would also
be a plus. A 3 or 4 speed brownie trans would also give
ya much needed gearing as well. Sounds like a hell of a
lot of fun. I would do it if I had it to do just like this. With
maybe a diesel up front.
abe
05-13-2017 08:30 AM
bassn1
06-21-2009 06:31 AM
Green Ford
36
08-29-2008 07:45 PM
