Why is my fuel milege gone bad?
I have not taken exact measurements, with everything going on i cant afford to fill up to calculate, but i make alot of the same trips multiple times, and add the same ammounts of fuel every time before hand and im noticing its not the same as far as having left over what i should, or not having enough at times. It sounds wiers but its just one of those things where you know your truck and you know what should be and you notice it isnt.
I wouldnt say its like going from 15mpg to 7mpg but its a big enough hit i can notice it.
Air filter is clean, fairly new about 2 months old. Oil is good, it hasnt been in that many miles ago either. I havent ran 4 wheel, hubs are free, equil ammount of loss on any tune from what id normally get on that tune.
And it seems as at the same time this started ive been smelling an odd smell when i stop shut off and park and get out. It smells like an oily smell or similar to my ccv vent. Which im not sure if thats a coincidence or not or ive just never picked up on that smell before or what, im just putting them together now.
Now, in addition, i must say my ccv vent tube ends right under my door because i didnt buy a long enough hose when i did it, i still need to take care of that. I can see the fumes rising when i stop at like a drive thru window or something.
Notice anything different with your boost or ICP? As stated above, winter blend kills mileage. It is about that time of year too.
How many miles on the injectors?
BobbyCHA
07-27-2007 01:39 AM
