1978 - 1996 Big Bronco
Factory AMP
Old Jul 15, 2003 | 04:14 PM
buddhabliss's Avatar
buddhabliss
Question Factory AMP
Hello all
I am trying to find the factory amp in my 94 Bronco.
Does anybody have an idea where the D@!& thing is located?
Thanks
Old Jul 15, 2003 | 05:18 PM
mrwizard's Avatar
mrwizard
Factory AMP
Which stereo do you have? Most of the radios didn't have seperate amps.
Old Jul 15, 2003 | 05:23 PM
buddhabliss
Factory AMP
It is the premium sound system. I had to get the adapter plugs
for it.
Old Jul 15, 2003 | 09:04 PM
joebronco94's Avatar
joebronco94
Factory AMP
on my 94 the factory amp is in the dash und the steering wheel on the radio side . about half way up yhe dash
Old Jul 16, 2003 | 10:22 AM
buddhabliss
Factory AMP
I found what I think is the amp under the dash but it has to plugs
side by side one is a short square and the other is normal.
The by pass kit only fits the one that is normal ???
Old Jul 16, 2003 | 11:12 AM
BillyBob69's Avatar
BillyBob69
Factory AMP
THat should be all that you need. The only thing you need to bypass is the speakers. The power and ground wires will still be used like normal.
Old Jul 17, 2003 | 08:06 PM
buddhabliss
Factory AMP
Thanks for the help it was under the dash and I had to cut one of the bypass conectors and hard wire it to the speaker wires of the new deck.
Once again thanks to everyone for the help.
Old Jul 18, 2003 | 12:42 AM
steve83's Avatar
steve83
Factory AMP
The amp actually plugs into the normal radio wiring connectors, so if you had dug around a little more, you could have unplugged it instead of cutting.
Old Jul 18, 2003 | 10:59 AM
buddhabliss
Factory AMP
I looked everywhere and only seen two plugs side byside each other one was rectangular which ran to the speakers and one was square that ran to the deck...the bypass connectors that came with the kit only connected to the connector going two the speakers and did not fit the square connector going to the deck so I had to cut that connector and wire it straight to the speakers wires from the deck.
Trust me I fooled around with this thing for hours and that was the only solution that I could come up with. This amp was not like the ones in the explorer at all.
Old Jul 19, 2003 | 01:16 AM
steve83's Avatar
steve83
Factory AMP
Yeah, I know.
Chris Crews
Feb 5, 2017 09:20 PM
mustanginca
Mar 27, 2006 12:10 AM
jfarmer
Aug 8, 2005 09:11 PM
jussam
May 24, 2004 04:54 PM
ryanben
Mar 27, 2003 10:32 PM
