7.3 cylinder wear?
10-06-2014, 02:13 PM
7.3 cylinder wear?
On a 7.3 engine, what is more likely to wear before the other?
Cylinder wear or piston ring wear?
Thanks
10-06-2014, 03:03 PM
Can't answer from experience for the 7.3 but every engine I've dealt with before it's the rings that are the farthest from their original measurements.
10-06-2014, 05:23 PM
When I opened my motor with 300k miles the cylinders still had cross hatching. Low compression from getting dusted.
10-06-2014, 05:30 PM
Thanks for the response guys,
Moose, So was your fix new rings?
10-06-2014, 05:50 PM
Quote:
Originally Posted by
bkuuz1
Thanks for the response guys, Moose, So was your fix new rings?
The cylinder that got the hit was scored. I had to bore it so complete rebuild. I'm still in the process on the obs forums
10-06-2014, 05:58 PM
okay,
I'm hoping more for dusting and ring wear. I probably won't be so lucky but who knows. A guy can always hope to get lucky.
cabloom300
07-13-2013 02:41 PM
74X4VAN
07-01-2007 05:29 PM
derherr65
08-31-2006 08:59 PM
mvvette97
02-23-2006 07:29 PM
