I am in the final stages of my build and I am searching for factory fuel lines from the sending unit to the pump. As well as a sending unit for the tank.
If I cannot find factory fuel lines what size is recommended 3/8" or 5/8"?
On the suction side of the pump in particular, it's really better to do it that way anyhow. The o-rings on the quick connect fittings are prone to letting air in if there's any restriction. They perform much better under pressure than they do under a vacuum.
Now just have to find a sending unit for my tank. Only ones I can find new are ridiculously expensize. Trying to source a decent used one isn't going to well. And I need to replace the fill neck with the diesel one.
