2003 brand new 6.0 won't start
We put a brand new 6.0 in the shop service truck at work. This is a f550. We put a egr delete while we were had the cab off. Put everything back together and now we cannot get it to fire. Will crank and crank but no fire.i have herd that the hpop can get a air lock and take a lot of cranking to get primed. Have herd that it needs at least 3 minutes of cranking time before it will start. I would guess we have about that much but not a lot over that. Not getting any rpm's during cranking. This was a ford factory motor and came with all sensors installed a
Ready. Not sure what direction to go now. Any help appreciated. Also the only code we get Is for throttle position sensor and we cannot get that to clear, but I don't think that is causing the no start.
Is the dash guage showing pressure? And fresh batteries... these things barely make the required 500 lbs start pressure with good batteries, mediocre ones won't cut it.
Do you have any diagnostics available...scanguage, or autoenginuity.
Not sure about this, someone can correct me, but I think a throttle position malfunction will still allow the engine to start, but will cause a forced idle.
We are using a jump box that is capable of both 24 and 12 volt in addition to battery's, so it turns over really fast. Pretty sure all connections are made but will check a 4th time. I will see if I can check some these other things today and get back with ya tonight. Thanks.
Was it running before you tore it down to replace the engine? Have you verified the fuel pressure? The F-550's have steel tanks that are known to delaminate and plug the pick-up screen in the tank and fuel filters. But you need to resolve the no RPM problem first as the PCM will not command the FICM to fire injectors until it knows what the engine RPM's are. It could be a faulty CKP ( crank shaft position sensor ) or a problem with the harness.
What are you suing to scan it with?
It may just be less work to stop at
someplace like Autozone and pick up
a SGII to read the live data.
Maybe doing a wiggle test can help.
Just do one thing at a time and check.
In other words you don't want one thing
to fix it and the other to unfix it.
Sean
Sean
Sean
Sean
I am starting to think that you may need something with more power and abilities
than just the phone app type of tool. Do you have power at the OBDII plug?
It would be nice if you had the ability to trigger some of the self tests with a scan-tool.
If you are going to be working on this a lot. You may want to look at something like
the AutoEnginuity Enhanced Ford Expansion - Riffraff Diesel Performance
Ford Module List
EEK I forgot you working on a F550 and they can use a different system.
This might be part of the problem that your having with the scan tool that
you are using. I would check with Clay over at Riffraff to make sure that
this will fit your needs.
Sean
Ford Module List
Sean
Not to long ago we had a guy with the same no start condition, he pulled his drivers side battery and the plate it sat on, the harness was smashed in-between the plate and almost cut into. it was the Cam shaft harness and they do have a replacement pigtail for it. but you really need to make sure you have sync and power to the PCM a Scan Gauge will give these readings along with V-ref 4.95 . be careful with cranking to long as that will burn out the starter and ware down the Battery's , Load test each Batt separate and check the FICM LP VP .
