1948 Ford F1 opportunity
[/QUOTE]Hello All, I am new here today and have an opportunity buy a running 1948 Ford F1. The fella that has is a mechanic told me it currently has a 351w and an automatic transmission. He put new brakes on recently as well. I'm just wanting something to drive around town and work on here and there. I will post a picture when I figure it out. Thoughts on if I'm crazy or ok for considering it.
Examine the sheet metal very carefully for bondoed over/ shoddily repaired rust damage. Typical rust spots: cab lower corners, door frame and skin bottoms, around 2 piece front fender seams, fender/running board junctions, running boards, There are others, but any rust repairs in these areas that needs redoing is going to be quite expensive to fix unless you are highly skilled body man. There are no repro assemblies made and few patch panels for the F1.
My and most other's advice on starting a project is always to seek out and buy the very best rust free sheet metal you can find/ afford, the mechanicals are a lot cheaper and easier to rebuild/replace.
The asking price isn't out of line if the truck is reasonably sound. Both Ax and Ray are spot on regarding expectations and starting points. Be sure to look this beauty over with a critical eye. None of these old gals are without issues. Part of your mission is to understand them as best you can and bump them against your readiness - both abilities and budget.
The only other piece of advice that I can give is take a trailer or have a Uhaul trailer on standby there. I'm sure it's a good decent truck, BUT you might end up stuck on the side of the road if you attempt a 2 hour drive right after handing over the money. I say this from experience.
Are you OK? Is any of us here OK? Likely not, but don't let that stop you from having fun with an old truck. 2 hours is nothing. I've gone 5 hours one way for two of mine. Welcome to the forum. Keep us posted on what you find.
