Any updates from the OP after everything was installed?
Sorry for the delayed response. Had a death in the family and had to drive 800 plus miles each way. Monitored the voltages the entire way. After warming up the voltages never dropped below 45 and never higher than 48.
I did return the Ford FICM and got a full refund. Did not even have to put up a fight, so kudos to the Dealer.
So, will need to arrainge alternate transportation for a few days so I can send my FICM in for repair. To bad they don't have loaners..........
My condolences...
If necessary, Ed will send you an FICM first, then you send in your core after you receive it. There is a cost associated with it, but at least you have the option.
