Coworkers truck missing, cutting off
Friend at work has a nice low mileage 2002 7.3 that has had some issues. Pulled the codes a week ago and some related to cps came up, he put in a new one from Ford and it hasn't gotten any better.
Riding down the road it will just miss once or twice and sometimes it will keep doing it until he pulls over. He turns it off and it will run fine for a while. Starts good, doesn't seem to be fuel related, does it hot or cold full tank of fuel. Checked the codes for him again and got>
PO733 Gear 3 incorrect ratio
p1209 injector control pressure peak delta test fault (he unplugged it at one point)
p1316 injector driver module codes detected
po344 CPS sensor A circuit intermittent (it has a new one he got from dealership)
po478 exhaust pressure control valve A high
p1211 icp higher lower than desired
He has a edge programmer on it but it does it in stock or turned on but may account for some of the codes.
Any ideas where to start?
This is not from an expert by no means.
I would unplug the edge. Check the wiring harness to look for shorts. Check the big plug for burnt pins and check ohms. Check under the valve covers. After that I would holler for help. I hope this helps some. I'm sure somebody with more know how will be along soon.
I haven't looked at the 42 pin connector other than make sure it was on tight, I was thinking UVCH all along but don't know how to check.
He also had some weird electrical stuff with his tach and computer that was throwing me off a bit but that may have been fixed when he put in new alternators and batteries.
How would I unplug the Chip/programmer Edge? it looks like mine (EVO) but it is different. He bought it used a few months ago and doesn't know much beyond that.
All I have is Dash Command, that's what I checked his codes with. I have the Edge EVO in my Excursion but it's never missed a beat in 220K haha..... Well not counting Alt's, water pumps etc. no running issues.
No fuel gauge, I'm not sure but I think it can monitor ICP but that's about it. The way it misses it's more like someone turns off the switch for a milli second. I opened the fuel bowl drain and turned on the switch and the fuel came out fast. I just don't think it's a fuel problem... But I could be wrong
look closely at the icp, oil will start to work it's way through it and casue it to mess up with out codes. aslo when the fuel heater shorts out it can throw all sorts of codes,
but first I second un hooking the edge chip, some chip plug directly into the computer.
I thought when the fuel bowl crapped out it blew a fuse, I could unplug it for sure. Also thought about the leaky windshield but it hasn't rained here in a while, well until tonight anyway haha.
Ohmed out his uvch's, all checked out but truck ran good all day. unplugged the chip, but it was this afternoon after it ran good all day. couldn't figure out how to log data on Dash Command. Anything else? we work 60-80 hours a week so kinda hard to spend to much time on it, trying to narrow it down.
Thanks
Thanks
Ohmed out his uvch's, all checked out but truck ran good all day. unplugged the chip, but it was this afternoon after it ran good all day. couldn't figure out how to log data on Dash Command. Anything else? we work 60-80 hours a week so kinda hard to spend to much time on it, trying to narrow it down. Thanks
Told him not to replace old #8, but he trusted Ford heh heh. Looks like they would know by now haha.
work4it
45
08-20-2017 06:00 AM
grayson20
04-24-2017 08:06 AM
BigTires
10-06-2011 09:14 AM
whitesdford
25
02-06-2010 02:54 PM
