Set of five 8-lug rims
on
Category: Wheels & Tires
Price: $100
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): '06+ Civic/CSX
Item Condition: CA
Engine: Part suitable for gas truck
8-lug, pulled from a 1970 Ford F250, but probably not original to that truck.
These rims are not "split rims".
16.5 X 6.75. Max tire 9.50.
The inner hub has a lip.
These rims use the "dog-dish" hubcaps that fit on the outside of the hub cap mounting bumps.
These rims are well-used but still functional.
No tires included.
Brass valve stems should probably be replaced, rubber gaskets are cracked.
As-is, where-is.
Located in zip code 94549.
17.5 inch diameter fits 16.5 inch tires. Well used.
Max tire size 9.50
NW 150
16
07-29-2014 12:29 AM
Danny in CO
17
12-26-2005 10:07 PM
