Ford truck information and then some....
  #91
Old 03-21-2015, 10:59 PM
SlikWillie's Avatar
SlikWillie
SlikWillie is offline
SlikWillie has a good reputation on FTE.SlikWillie has a good reputation on FTE.
This thread is GOLD!!!! 77&79F250, you are one awesome guy for doing all this work. We all really appreciate it. Thank you.
  #92
Old 03-21-2015, 11:16 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Used OEM parts guy
77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.
Just piling up and passing on the good words from a many FTE members over the years and a select few that post diagrams.
Thanks for the thanks, and thanks to all the guys that provided diagrams and info and do things like HIO Silver, provide way more awesome tech threads.
  #93
Old 04-01-2015, 11:08 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
And it just keeps growing.
  #94
Old 04-11-2015, 07:24 AM
77&79F250's Avatar
77&79F250
Used OEM parts guy
And some more stuff from the good ol folks on FTE.
  #95
Old 04-25-2015, 10:13 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
And some more.... like tilt wheel steering column break down. And thanks to Number Dummy we know that part # 3B661 is the culprit for a tilt wheel that will not lock.
FYI there are NONE that are NOS available and it is NOT reproduced according to him.
  #96
Old 04-26-2015, 10:37 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
  #97
Old 04-28-2015, 06:33 AM
77&79F250's Avatar
77&79F250
Used OEM parts guy
And some more thanks to fellow FTE members.
  #98
Old 05-21-2015, 06:20 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
The ever elusive intermittent wiper control box and the splice wire.
D3TZ-17C476-A (replaced D1ZZ-17C476-A) Intermittent Wiper Governor.
Thanks to the FTE member that posted the pic.
  #99
Old 05-24-2015, 08:49 AM
77&79F250's Avatar
77&79F250
Used OEM parts guy
And another one..thanks to ND.
  #100
Old 06-04-2015, 10:26 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
Bam....or more like E-brake. Sorry I have been slacking on the info I have been working a new job.
  #101
Old 06-07-2015, 09:27 AM
77&79F250's Avatar
77&79F250
Used OEM parts guy
Another pic and some updates on windshield wiper switch locations, all thanks to ND.
Intermittent (delay) wipers were optional on 1973/79 F100/350's and 1978/79 Bronco's. Intermittent is not another name for low speed!
D1OZ-17A553-A .. Two Speed Wiper Switch-Used with Intermittent Wipers (Motorcraft SW-1010) / Marked: D1OB-17A553-AA / Obsolete
1973/79 F100/350 / 1978/79 Bronco // 1971 Fairlane/Torino/Montego.
6/7/2015 updated sources:
CAIN FORD-LINCOLN in Cornelia GA has 1 = 706-778-2121.
DON'S TRUCK SALES in Fairbank IA has 1 = 319-365-2751.
PEROGIE ENTERPRISES in Highstown NJ has 1 = 609-448-5593.
WOLFE FORD in Lidgerwood ND has 2 = 701-538-7337.
WESLEY OBSOLETE PARTS in Liberty KY has 2 = 606-787-5293.
GREEN SALES CO. in Cincinnati OH has 7 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 36 = 800-476-9653.
  #102
Old 06-27-2015, 09:25 AM
77&79F250's Avatar
77&79F250
Used OEM parts guy
So if you have a SC with hinge open windows and need a replacement latch, you can get one off a 73 Pinto or a 73/77 Maverick, since it is the same latch. Part # 303A24.
Thanks ND.
  #103
Old 06-28-2015, 10:17 PM
DavesOldTruck's Avatar
DavesOldTruck
DavesOldTruck is offline
DavesOldTruck is starting off with a positive reputation.
1974 F250 instrument cluster connector.
Your information is top notch and I hope you can help me once more. I have removed the instrument cluster from my 74 F250. Connector 13 on the instrument cluster connector has two wires running to it one black (I presume ground) the second a kind of purple color. When the ignition switch is tuned to ACC the purple wire gets hot indicating to me that there is a direct +\- connection in this circuit. I have seen a schematic for this connector somewhere but cannot find it again. I need to be sure that this is wired correctly and what this wire runs to before I reinstall the cluster and close the dash. Can you help me find this information ?
  #104
Old 06-28-2015, 11:12 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
Looks like on this one the PPL/WHT goes to the Low Brake Switch and then the Ignition Switch.
Maybe this will help?
  #105
Old 07-08-2015, 11:53 PM
77&79F250's Avatar
77&79F250
Used OEM parts guy
If it will load?
File Type: pdf
Quick Reply: Ford truck information and then some....
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
