Now I know why...
Old Sep 26, 2014 | 09:58 AM
CharlaineC's Avatar
CharlaineC
Now I know why...
So I now know why my break warning light was broken as if someone pried it apart to TAKE THE LIGHT OUT. Hear is what happened, I found and replaced the broken bezel and light with a new one from the salvage yard, and while working on Pearl last night I decided i'd start her for a bit. Turned her over and poof bright red break warning light. Now I admit that at the time I thought it was an e-break warning light so i spent a few moments looking for the switch to unstick it. After not finding it started to rain so I gave up. While on FTE and fordification I searched about the light to find the switch. Well thats when I learned it was a break warning light connected to a valve that needed to be reset. OK simple. NOT!!! now I cant find it am looking everyplace i'm reading and its not there. Turns out its under Pearl attached to the frame and GUESS WHAT!!! One of the two lines that connect to the rear are cut. So now I need to replace the rear lines, I'll take a photo and post it soon.
Old Sep 26, 2014 | 10:03 AM
quinletc's Avatar
quinletc
While that really sucks, at least you found it this way, instead of figuring it out after you were unable to stop and ended up injured or dead.
Old Sep 26, 2014 | 10:47 AM
Rasputin53's Avatar
Rasputin53
Rules of Auto Restoration:
1. Before it can go, first it must stop.
Old Sep 26, 2014 | 01:26 PM
HIO Silver's Avatar
HIO Silver
Don't ya just looooove previous owners?
That's why a thorough inspection and "hack patrol" should be done to every new-to-you vehicle. It's amazing the crap that can be found.... household wire nuts, coat hanger wire, Chinese hardware, duct tape, chicken wire & filler, bent box nails for cotter pins, drywall screws,.. the list goes on and on and on.
Old Sep 26, 2014 | 03:01 PM
351Cleveland C4's Avatar
351Cleveland C4
I was lucky enough to get my truck from my ol' man. So I/he knew everything about it.
Old Sep 26, 2014 | 08:07 PM
CharlaineC's Avatar
CharlaineC
yea ive been told i could do something in court but its a moot point. hes a kid and doesnt know how to care for a truck. itll be better to fix it and go over there and show him the photos of everything and scare him
Old Sep 26, 2014 | 09:14 PM
crazed87bronco's Avatar
crazed87bronco
The reset gets many people on these systems. been a topic that comes up every so often so it's not uncommon to be overlooked while trying to figure out the problem. There's a good thread on this here somewhere. As to previous owners there's so many things I've seen over the years that amazes me and ask's what were they thinking? Or even doing hahaha
Old Sep 27, 2014 | 01:01 AM
trozei's Avatar
trozei
My previous owner painted over the brake warning light when he spray-bombed the interior. It was a truck he was trying to restore for his late grandfather, the original owner, so I'll give him the benefit of the doubt of having no idea what that light was for.
Also, my lazy butt never got around to scraping the paint off of it...
Old Sep 27, 2014 | 04:16 PM
CharlaineC's Avatar
CharlaineC
We should do like one of the other parts of the board and start a P.O. Headach thread. as a place for all the issues we find.
Old Sep 27, 2014 | 05:13 PM
HIO Silver's Avatar
HIO Silver
Here's one from the Dentside forum: https://www.ford-trucks.com/forums/9...se-owners.html
Old Sep 27, 2014 | 06:25 PM
CharlaineC's Avatar
CharlaineC
thats what i was talking about we should start one
Old Sep 28, 2014 | 06:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
So I now know why my brake warning light was broken as if someone pried it apart to TAKE THE LIGHT OUT.
I found and replaced the broken bezel and light with a new one from the salvage yard, and while working in Pearl last night I decided i'd start her for a bit. Turn her over and poof bright red brake light.
Now I admit that I thought it was an e-brake warning light (it's not), so I spent a few moments looking for the switch to unstick it.
There is no e-brake warning lamp on these trucks. Some people assume that's what it is, as it's located near the emergency brake pedal.
This is the low brake fluid warning lamp, its plastic switch (has a 2 prong connector) threads into the Brake Pressure Differential (aka proportioning) Valve.
This valve is located below the master cylinder...usually on the frame rail.
C8AZ-2B264-A .. Low Brake Fluid Warning Lamp Switch / 1968/79: F100/350, Bronco, Econoline & misc Passenger Cars / Available from Ford and auto parts stores.
This switch is a notorious POS! Cracks develop in its threads causing brake fluid to seep out. When this occurs, the low brake fluid warning lamp comes on...and stays on!
Thank you for your service and you have quite a wide range of interests. Gun collecting, if you recognize this: OBFM .. your collection includes an old lever action.
Old Sep 28, 2014 | 11:45 PM
CharlaineC's Avatar
CharlaineC
Number Junkie your talking about my Marlin Model 1893 rifle, cal.30-30 Winchester leaver action.
a12play12
Feb 15, 2016 05:28 PM
dp045
Electrical Systems/Wiring
Mar 3, 2013 06:43 PM
jared66
Aug 31, 2009 08:17 PM
77hiboyboy
Jan 16, 2005 06:14 PM
1988ford
16
Mar 1, 2003 11:03 AM
