Dana 44 Seal & Gasket Replacement
I should be on my way to getting this thing road worthy.
When the front of my pumpkin got oily it was usually that damn C2 power steering pump puking itself.
How many miles on this truck?
You may need a FMS.
They will run all over the crossmember and drip down.
A fresh 'straight up' timing set would probably do wonders in a 460 this old.
You may need a FMS.
You were right ArdWrknTrk. It was mainly that old blowed out power steering pump. The front diff is leaking a little but since it's so easy to add gear oil I just plan to keep an eye on it through the winter.
I bought a timing set specifically to set the timing straight up. Though I ran out of time to do it before it got cold but I have it none the less. Along with a new Gates water pump. I will likely use them both when I rebuild it in the spring. Which I'm really looking forward to.
joegeds
10-26-2014 08:22 PM
plugugly
02-17-2004 07:45 PM
