6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
What Did You Do To Your 6.4L Today?
Old 02-11-2015, 11:51 PM
73fan's Avatar
73fan
73fan is offline
I basically just drive mine. I like how it starts at -25C without being plugged in! Ha ha.
Playing in the snow.
  #167
Old 02-14-2015, 09:28 PM
mohle's Avatar
mohle
mohle is offline
Did my serpentine belt, tensioner, rear diff oil and fuel filters today.
  #168
Old 02-15-2015, 09:25 AM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
Was discussing the weather with one of my brother-in laws (a Windsor, Ontario native) and he pulled out his phone and gave me a time line until his retirement, in hours, minutes, and milliseconds,LOL, and stated his next January, February, and March will be spent in Texas on the Gulf coast. I stated he should be thankful he doesn't live in BC or Alberta, and he said those people up there JUST aren't right. LOL
I think your post goes along with that statement.
  #169
Old 02-15-2015, 11:00 PM
Hunter40's Avatar
Hunter40
Hunter40 is offline
I used it to bring this home!
  #170
Old 02-26-2015, 09:54 AM
bigblockford_390's Avatar
bigblockford_390
bigblockford_390 is offline
I replaced the heating pads on the driver seat last night. Took about 3 hours from start to finish and my butt is so much happier now!
Here is the write up with pictures for anyone who is interested in taking this project on.
https://www.ford-trucks.com/forums/1...placement.html
Jeff
  #171
Old 02-26-2015, 11:06 AM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
Nice write up!
  #172
Old 02-28-2015, 07:54 PM
73fan's Avatar
73fan
73fan is offline
What did I do to it today? Hardly worth mentioning, removed the broken backup sensor. But last week Saturday I replaced the EGT probe on passenger side up pipe. It's just nice when the display shows actual temperature rather than 92° all the time. And, while I had it in the shop for that I drained the water separator and what do you know! It dribbled a surprising amount of water. So I let it run for a while to be certain ALL water had escaped.
On another note, that same day I tore the "secondary" hood release cable. Buddy at Ford told me that's common for the early '08. Hmm...
  #173
Old 03-01-2015, 12:25 AM
73fan's Avatar
73fan
73fan is offline
Oh, and this was the Saturday before!
  #174
Old 03-02-2015, 07:01 PM
dlibson's Avatar
dlibson
dlibson is offline
Today I replaced the shocks, fixed some exhaust mounts that were messed up from the PO, changed the tranny filter and fluid, and gave it a look over.
Radiator is on the list, as well as a passenger side wheel hub assembly...
  #175
Old 03-04-2015, 09:29 PM
73fan's Avatar
73fan
73fan is offline
Hmm, you're changing filters...I need to change fuel filters! Thanks for the reminder!
  #176
Old 03-05-2015, 06:11 AM
dlibson's Avatar
dlibson
dlibson is offline
Ha, I did that too a few days ago. Fuel and oil change.
  #177
Old 03-08-2015, 11:20 AM
parkland's Avatar
parkland
parkland is offline
Originally Posted by bubbasz1
I broke down and put my winter cover on, Oh what a difference, heat!!!
I put cardboard over the rad once, and it didn't seem to make a difference in warmup time.
Although I'm sure it retains more heat though. Having known a few guys that trashed motors from overheating with the rad covered, I'm out.
Anyone know if and how much fluid goes through the rad when cold?
  #178
Old 03-08-2015, 08:01 PM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
How did they overheat their trucks??
Ford sells it and says it's ok to use up to 50 degrees as long as your not towing.
Mine heats up faster, plus it keeps most of that salt crap off the front of the engine, and that alone is worth the cost of the cover.
IMO
  #179
Old 03-08-2015, 09:38 PM
dlibson's Avatar
dlibson
dlibson is offline
I've used one plenty, never heard of anyone using them properly hurting their truck...
  #180
Old 03-08-2015, 10:02 PM
bigblockford_390
I changed out the rear axle pinion seal and drained the old gear oil out. Cleaned everything up and topped off with new 75/140 gear oil. Really not a bad job at all, 3 hours total over two days to complete it.
Jeff
Quick Reply: What Did You Do To Your 6.4L Today?
