Intermittent battery light
Old Sep 23, 2014 | 09:22 PM
Cy Quinn's Avatar
Cy Quinn
03 F250, 7.3, battery light comes on when cold. Engine runs terrible. P0308 comes up occasionally. Once truck warms up, light goes off, truck runs perfect. Some sort of voltage issue? Wondering if the misfire code is associated with voltage? Thoughts?
Old Sep 24, 2014 | 06:30 AM
Supercab's Avatar
Supercab
WOW!!! Your VERY FIRST POST!! (I made mine over 15 years and 3 trucks ago!!)
Welcome aboard! Not sure what the code PO308 is, but it sounds like your alternator may be on its way out.
You can have it checked and if its not working as it should you should have IT rebuilt by a quality, home town type auto electric shop over buying a questionable unit at a box store.
Old Sep 24, 2014 | 12:58 PM
Stewart_H's Avatar
Stewart_H
What's your voltage when this happens?
Stewart
Old Sep 24, 2014 | 01:04 PM
Pikachu's Avatar
Pikachu
The P0308 is a misfire code for cylinder 8. That would explain the rough running.
Old Sep 26, 2014 | 07:31 PM
Cy Quinn's Avatar
Cy Quinn
This is occurring with brand new alt....not sure what the voltage is, I'll check.... Thanks for the help!
Old Oct 6, 2014 | 07:08 AM
BobbyDiesel71's Avatar
BobbyDiesel71
The battery light is flickering due to a bad wire in the three wire pigtail
cut it off and replace it with a new one
The three wires are pulled up and not making good contact in the alt
I had this issue and fixed it after many bad alt replaced/new batteries
dapozer
Jan 10, 2012 10:08 PM
lionsteve
Sep 29, 2010 07:52 PM
tobacco farmer
Apr 11, 2010 07:07 AM
rkp
13
Dec 21, 2008 10:29 PM
greenterror
Apr 27, 2007 04:40 AM
