Modded Suspensions Call - Request your measurents
#122
#123
I have an adjustable track bar (panhard rod), drop track bar bracket, and drop pitman arm. I had Moog sway bar end links which bolted up fine but the sway bar was far from level. I'm sure if you flip the frame-to-sway bar endlink mounts around, that would bring the sway bar closer to level. I ended up going with a set of Skyjacker extended sway bar endlinks.
No problems with the brake lines. I'm running 295/60/R20.
#125
#127
#128
#129
Front 20
Rear 24.5
The ride is a lot better not real truck like either. Kinda suprised me.
#130
Ok, I'm a little late to the party even though I had a reminder or two...
I installed new Ford V codes and SRW C's, about 2 years ago and ~25000 miles. I have the stock Excursion block in the rear. Personally I feel the best way to measure a change in suspension is at the jounce bumpers, measuring anywhere else can get confounded by worn body mounts and the Eddie Bauer/Limited cladding will influence the fender lip measurements...
From the center of each wheel to the radius of the cladding, full tank....
LF 24"
RF 24-1/8"
LR 25-3/8'
RR 25-1/4"
Thank you.
LF 24"
RF 24-1/8"
LR 25-3/8'
RR 25-1/4"
Thank you.
#131
LF 24"
RF 24-1/8"
LR 25-3/8'
RR 25-1/4"
Thank you.
LF 24"
RF 24-1/8"
LR 25-3/8'
RR 25-1/4"
Thank you.
#132
#134
#135
Before and after
Before;
Stock 2003 Limited 7.3 4X4
149,000 miles
As far as I know the truck was 100% original suspension
LF - 22.5"
RF - 21.5"
LR - 23.25"
RR - 23.25"
Stock suspension
After;
Kit purchased from ATS
Front - X Code Replacement leaf springs with Bilstein 5100 Shocks
Rear - ATS Modded C code leaf springs and Bilstein 5100 shocks
Also completely rebuilt the front end with new Hub and axle seales, upper and lower ball joints, steering stablizer, drag link, sway bar links and track bar.
LF - 24.75"
RF - 25"
LR - 27.75"
RR - 27"
After ATS X and C spring upgrade
149,000 miles
LF - 22.5"
RF - 21.5"
LR - 23.25"
RR - 23.25"
Stock suspension
After;
LF - 24.75"
RF - 25"
LR - 27.75"
RR - 27"
