On a 50 f1 is there any side to side adjustment on the radiator saddle?
My hood seems to be about 1/2" off center when it is closed, I have to fuss with it to get it to latch. It could be the grille header that is off. Any ways, I though that I may be able to move the radiator saddle over about 1/2" to compensate. Is that possible. Thanks for any and all input.
Inner fenders seem to be properly located and cab mounts appear to be solid. From the looks of the inner fenders the truck has been hit pretty hard, I think on the pass. side. I replaced one inner fender and straightened the other. I think I will reassemble the front fenders,( not the ones that were on it) and grille and see where I am at after that. I just thought that if I could move the radiator saddle over 1'2" all would be good. thanks for the response.
I have a similar problem on my '50 F2. As I was disassembling things I found that the front cab mount bolts (4) had worn through their collared washers and elongated the frame mounting hole. You will have to remove those bolts and jack up the body (and probably do some cleaning) to see this clearly. If you don't check this and if you have this problem nothing that you can do will solve the problem as the cab will move around on the frame while driving. It will be a crap shoot if it settles back to the right spot.
An ⅛" elongation at the front cab mounts could easily translate to ½" all the way at the front go the hood.
I have been in the process of installing new fiberglass fenders and new grill, everything is coming together pretty good. I think my hood is sprung and it is not the hood I am going to use. Tomorrow I will get the grill header bolted in permanently and then change the hood, so then I will know for sure what is going on. My frame is not diamond"d and my radiator saddle is ok. I'm glad I don't have the issues that Pete is dealing with.
Ok Pete, my radiator shroud was diamond'd and letting my fenders sag on both sides. the PO cut the upper brace out and when I put my grille header in it lacked meeting the fenders by about a 1/4 inch on both sides. I pulled the shroud back together, put in a new brace , the fenders meet the grille header and the hood is closing at center. All is good on the home front, no rust in the lower cowl and the cab mounts are solid. So it is on to the next cluster , well you know what I'm talking about. The only thing that bugs me is the front inner fender being between the grille header and the upper fender, it doesn't make for a real tight fit.
48' fordster
10-17-2006 06:43 AM
