56 F100 Tilt front help
I am building a 56 F100 here in Australia, & am having trouble with building the tilt front hinges. It is a all steel front with no front bumper will be raised with electric actuators. I have seen pictures on the net, but I need some dimensions if anyone out there can help.
Pete
Pete
Usually the dimensions are dictated by the location of the hinges...which are usually mounted on top of the frame horns. There are various designs for these hinges and lift actuators so your specific design will have a lot to do with how you implement it. For instance, do you intend to keep the fender intact and slide the frontend forward before lifting or are you going to split the back portion of the fenders to allow a straight up lift without a forward slide?
Here are a couple of pics of one of the nicer hinge/actuator setups that I have seen...
Look on page 4 you may want to contact johnnynobody
One piece tilt front end - Page 4 - Ford Truck Enthusiasts Forums
s-man56
41
11-13-2019 01:34 PM
iforeman
02-01-2013 06:54 AM
53ford
04-14-2006 07:44 AM
Bushwacker
07-14-2000 08:09 AM
