Potential Buy 88 F700
I am looking at buying a 88 f700 for farm use. Getting gravel, hauling hay, hauling wood, etc. I do know that it has the 170 hp version of the 6.6 diesel. I also know that it has an automatic. The vin is 1FDXK74P9JVA17047 the numbers on the door tag were :207k74300bk8aa2jn. I think that the trans code is the AA and the axle code is 2jn. The tag on the axle pumpkin had a lot of numbers that were really small, but I noticed that it said 529 in one corner. This truck has less than 90k on it and was used by a city for what I am not sure, the bed doesn't dump, but looks like a dump bed. All of the stuff that is needed to make it dump is included with it, and I can handle the conversion. The guy selling it is cleaning out his parts shed and is going to throw in a allison mt-643, and says that it will fit it. The 643 is bolted to a cat 3208 that he got out of a fire truck that he just needed the engine for.
Anyway my questions are what is the axle ratio?
What trans does it have?
Will the included mt-643 bolt up to the 6.6?
Thanks
Thanks
VIN: 1FDXK74P9JVA17047 // Certification Label: W.B. 207 / TYPE GVW: K743 / 00 / BODY: BK8 / TRANS: AA / AXLE: 2JN
X = Class 7 - Air Brakes - 26,001-33,000 lbs. Gross Vehicle Weight Rating.
K74 = F700 Conventional Cab Diesel.
P = 6.6L Ford Turbo Diesel.
9 = Check Digit - FoMoCo use only.
J = 1988.
V = Kentucky Truck Assembly Plant.
A17407 = 1988 Numerical Sequence of Assembly, the trucks specific serial number.
207" Wheelbase.
K743 = F700 Conventional Cab Diesel.
00 =
BK8: BK = Chestnut all Vinyl - Bench Seat / 8 = Conventional Cab.
AA = Allison model AT-545 Automatic Transmission.
2JN:
2J = Rockwell model RS-20-145 Single Speed Rear Axle / 5.29-1 / 21,000 lbs. Rear Axle Capacity.
N = Ford 9,000 lbs. Capacity Front Axle with Power Steering.
